6.9 Wont start - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 8yourv8, this thread has received 3 replies and been viewed 1255 times.
post #1 of 4 (permalink) Old 09-27-2010, 05:15 PM Thread Starter
8yourv8's Avatar
6.9 Wont start
Hello Guys
I am not going to lie I have never worked on a 6.9lt
But My girlfriends dads bought this truck and it will not start
The guy that had it before said it ran fine then it died do to lack of fuel
The guy put in a new injector pump in but still no fuel anyone know how i can check this or how to install one?
Thanks guys
Driving 2007 Chevy LTZ CCSB LMM so far just EGR delete, Straight Pipe, ported fuel fitting, trans-go and PPE HOT RACE
SOLD SADLY 2004 F-350 CC SB 4Inch lift 35in tires on 20s 6.0lt EGR delete ported intake AFE stage 2 SCT Tuner ARP stud's back to stock injectors CFM Large mouth and 5" Magnaflow with 4"Down pipe 6" tip
8yourv8 is offline
post #2 of 4 (permalink) Old 09-28-2010, 01:30 AM
dieselboy740's Avatar
It's air bound. You will need to prime the system. Pull the filter off and fill it up. Pull the return line off the injection pump and fill it with fuel and make sure your lift pump is working. If it still doesnt fire then crack a few lines at the injectors and crank it till you get fuel then tighten them back up.
Also make sure you have power to the pump
95 bronco 94 idi turbo, intercooled, maxed out pump, custom compressor, custom downpipe, 12* timing, oba, d60, 10.25, e-locker, exocage, zf5, etc.....
2011 f-550 6.7L 12ft service box, shop on wheels
80 merc 300sd, hx35, intercooled, straightpiped, modified pump, egr delete, etc.....
dieselboy740 is offline
post #3 of 4 (permalink) Old 09-28-2010, 08:11 PM Thread Starter
8yourv8's Avatar
Okay I will take a look and let you know
Thanks for your help
8yourv8 is offline
post #4 of 4 (permalink) Old 10-08-2010, 01:57 AM
Cincinnati Guy's Avatar
When you first install a new injector pump you will have a load of air in the system, like stated above you need to prime the system. Crank a few seconds let it fit as few and keep doing this until you start getting smoke out the tailpipe, that lets you know your starting to burn the fuel. You then will be getting close to getting it running. If this dont help get back with us and let us know.
FORMERLY SMOKIN85
Ryan
1994 F-350 SRW Crew Cab 4x4 Dana 60 Front, 4.10 Gears with a E4OD
SOLD-1992 F350 7.3
Ryans 92 Diesel Pictures
SOLD-1985 F250 6.9 NA
Ryans 85 Diesel Pictures
The Diesel Garage Mafia
Singles Club
Ridin' Dirty Club #24
Don't forget to vote in TOTQ
Cincinnati Guy is offline
wont start mani 2003-2007 6.0L Power Stroke 21 09-07-2009 10:33 PM
05 6.0 Wont Start Snox49x 2003-2007 6.0L Power Stroke 1 02-16-2009 05:10 PM
wont start doob51 5.9L Cummins 12 Valve (1994-1998.5) 3 05-06-2007 02:05 PM
05 wont start twin_turbocummins05 5.9L Cummins (2003-2007.5) 11 04-21-2006 09:27 PM
