1984 6.9 shifting problems - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by rollernose, this thread has received 3 replies and been viewed 4004 times.
post #1 of 4 (permalink) Old 10-16-2010, 09:50 PM Thread Starter
I have a 1984 F 250 6.9 C6 trans. It shifts @ 35 MPH to 2nd and 55 mph to 3rd. I replaced the vacuum pump, vacuum regulator valve, and vacuum modulator. Pump first, it was bad, no breaks/ heater etc... that is all working fine now, shifting was still bad. Modulator next, poor shifting continued I adjusted the screw in the inlet tube and eventually took it all the way out to see what would happen, it never changed the shifting problem. Although it does down shift @ 45 mph which the stock modulator did not do. Replaced the VRV no difference in the shifting Checked all hoses, swapped the two hoses on the valve top for bottom no difference. I bypassed the VRV altogether and still no Difference even with direct vacuum to the modulator! ANY IDEAS!!!!!!! I'm tired of playing with it. It shifts firm and seems to be fine mechanically just very uncomfortable to drive like this!
rollernose is offline
post #2 of 4 (permalink) Old 10-18-2010, 02:42 AM
Cincinnati Guy's Avatar
Your VRV valve needs calibrated to shift at the correct RPM. Did you do that or just put it on?
FORMERLY SMOKIN85
Ryan
1994 F-350 SRW Crew Cab 4x4 Dana 60 Front, 4.10 Gears with a E4OD
SOLD-1992 F350 7.3
Ryans 92 Diesel Pictures
SOLD-1985 F250 6.9 NA
Ryans 85 Diesel Pictures
The Diesel Garage Mafia
Singles Club
Ridin' Dirty Club #24
Don't forget to vote in TOTQ
Cincinnati Guy is offline
post #3 of 4 (permalink) Old 10-19-2010, 04:17 AM Thread Starter
location doesn't matter
It doesn't seem to matter where the adjustment is on the vrv shifts the same no matter where
post #4 of 4 (permalink) Old 10-24-2010, 01:28 AM
Super Moderator
John_G's Avatar
No vacuum to the Modulator Valve will result in both harsh and late shifts.
Be sure to check all the vacuum lines for leaks, even a small leak can keep the VRV/MV from working correctly.
I vote for LIBERTY!
John_G is offline
SCT Shifting problems JoeS500 2008-2010 6.4L Engine Tuner Forum 10 06-24-2010 02:27 AM
Shifting problems Rwhat 2003-2007 6.0L Power Stroke 9 07-29-2009 06:06 PM
Shifting problems Need help!!!! jktcummins 5.9L Cummins (1998.5-2002) 6 03-06-2007 09:58 PM
shifting problems imported_99powerstroke 1994-2003 7.3L Power Stroke 8 11-25-2006 03:01 PM
Shifting Problems 86F250Diesel 7.3L and 6.9 IDI (Pre 1994) 6 09-19-2006 02:42 PM
