1993 hard start - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by trapper24-7, this thread has received 12 replies and been viewed 6444 times.
post #1 of 13 (permalink) Old 11-23-2010, 02:49 AM Thread Starter
Send a message via AIM to trapper24-7
1993 hard start
I bought a 1993 f-250 turbo diesel and it will not hardly start with out being plugged in, and even with it plugged in it is still having some problem starting. I left it unplugged last night and it is 50 degrees out and it would not start with out being plugged in today. I just put in some new glow plugs and that still did not help. Any thoughts y it is doing this? thanks Mitch
trapper24-7 is offline
post #2 of 13 (permalink) Old 11-23-2010, 07:25 AM
4play's Avatar
Does the wait to start lamp illuminate for at least 4sec if not closer to around 20sec when cold) Are you sure the glow plug relay/controller is working? Is there power to glow plugs when you key it on? Does the cold start advance and high idle solenoid work (both on IP)? Are the batteries and starter good? Sorry for the questions but a little more info will help out here.
Listen for the glow plug relay to click when you key the ignition on, check the engine harness connections for damage. check fuse links in engine harness and off of the B+ side of the starter relay. check the trigger wire on the relay for power when key is on.
If you dont have the cold start advance and high idle you might check that your getting power through the cold start switch which is right behind the thermostat housing. I doubt this is the direction for your concern but these functions do help in cold starts and running.
I know you said they are new but there are easy steps to test glow plugs themselves. Unplug the wire at to of glow plugs, either measure resistance (less than 2ohms) or connect a test light to battery+ terminal. then probe all 8 glow plugs individually. If the GP is good the test light should light.
4play is offline
post #3 of 13 (permalink) Old 11-23-2010, 03:38 PM Thread Starter
Yeah the start lamp when it is cold is about 10 sec around there. The guy I bought it off of said he put a new relay on it, and the relay does click but i need to check it to make sure. When it is plugged in, it will start if I pump the throttle some. When it does start it has a high idle for about 3-4 sec, but is that from me pumping it and it getting to much fuel? But if I don't pump it, it has a lot harder time starting. There is new batteries in the truck and the starter seems to be good. Thanks 4Play
post #4 of 13 (permalink) Old 11-23-2010, 04:07 PM Thread Starter
Ok so i was checking the glow plugs like you said and the test light did not come on I checked two of them. I went to pull out one of the glow plugs and put a new on in to see if the light would come on and the new glow plug that i put in last week is swelled so how do i get it out? So i am guessing my new glow plugs are bad?? What the heck would make the new glow plugs bad after just a week?
post #5 of 13 (permalink) Old 11-24-2010, 03:42 AM Thread Starter
I found my problem all my new glow plugs are bad, and i just put them in 5 days ago? So what would make that happen? The relay is kicking off after 23 secs so i don't know what to think!
post #6 of 13 (permalink) Old 11-24-2010, 02:17 PM
Super Moderator
John_G's Avatar
If they are not OEM (Ford/Motorcraft/International) they will fail and fail and fail...... forever.
Even with OEM GPs, if you get 5 years from them all, you are doing ok. Some go longer, some shorter, but 5 years is about the average.
Pumping the accelerator doesn't hurt anything at all, you are not pumping fuel in, you are setting the cold start device into fast idle mode, that is all and a good thing. Just don't stab the accelerator WHILE you are cranking it over or after it starts.
I vote for LIBERTY!
John_G is offline
post #7 of 13 (permalink) Old 11-24-2010, 02:53 PM Thread Starter
So you are saying i got crappy glow plugs, I put the same one that were in the truck which were 1108 Auto Lights. But you are saying i need to get Better glow plugs and they will not burn up in 5 days? You think for sure it is just crappy glow plugs and not anything that the truck would have done to burn all of them up? Thanks
post #8 of 13 (permalink) Old 11-25-2010, 12:12 AM
Super Moderator
John_G's Avatar
The GPs operate on 12V, all the time, every time.... unless it was boosted off with a 24V charger or something.
They SHOULD last 5+ years, if you buy something that doesn't last as long as it should, well in my book that equals a junk part.
Aside from ether (starting fluid) and using too much voltage with a charger/booster there is really nothing that would cause them to fail on the engine/truck side unless they never turn off (relay stuck etc).
I vote for LIBERTY!
John_G is offline
post #9 of 13 (permalink) Old 11-25-2010, 12:52 AM Thread Starter
I did put a 12v charger on the truck and the booster was on for a little bit. so you think that's what it was?
post #10 of 13 (permalink) Old 11-25-2010, 03:12 AM
4play's Avatar
The charger could have done it, but what was said earlier about the glow plugs is that a lot of people have considered anything but the motorcraft glow plugs to be junk. Replace them with Motorcraft or another brand stating "BERU" on them.
The glow plug relay could have stuck on causing the plugs to burn up too. I would make sure the relay is good. It seems hard to imagine that all 8 plugs could burn up in 5 days just because they are cheap or junk plugs.
4play is offline
my first hard start harleystroker 2003-2007 6.0L Power Stroke 4 01-30-2010 10:21 AM
F350 hard start to no start spike 1994-2003 7.3L Power Stroke 3 12-07-2007 03:30 AM
Hard to start / white smoke at start, again. bsigg 6.5L Diesel Engine 2 11-27-2007 04:57 PM
04-17-13 Hard Start Or No Start - Gpcm Connector Service Kit Available - 6.0l Engine Squatch Ford Oasis requests 0 03-23-2007 12:55 PM
CRANK NO START, HARD START, RUNS ROUGH AT IDLE - 6.0L 2005 F, E-Series,and Excursion PSDPlayer 2003-2007 6.0L Power Stroke 0 10-08-2005 08:32 AM
