1984 6.9 Wont turn over and crank - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BlowinSmoke, this thread has received 4 replies and been viewed 4973 times.
post #1 of 5 (permalink) Old 11-29-2010, 12:43 AM Thread Starter
BlowinSmoke's Avatar
I do not own this truck it is a friends so ill try to give as much as i can.
The trucks date is 05/84 its a 6.9L banks turbo diesel, has two batteries and the battery isolater by sure power.
Theres power to the ignition and everything but when the keys turned over whats heard is a hard clunk ? (not heard personally by me)
Sorry this is a plain and open post I'll get what I can when I can.
BlowinSmoke is offline
post #2 of 5 (permalink) Old 11-29-2010, 12:54 AM
Super Moderator
John_G's Avatar
It sounds like either the engine is locked up or the starter is locked.
You need 12V to the starter B+ terminal AND good ground connections between the starter/engine and battery pack for the starter to work, even a new one. I'd check all the connections first and I don't mean LOOK at them, I mean remove, clean and reassemble (with the batteries dosconnected of course).
I vote for LIBERTY!
John_G is offline
post #3 of 5 (permalink) Old 11-29-2010, 06:58 PM
Do not try to start it till you check it out, an oil filter is cheap and removing it and cutting it apart looking for metal is always a good idea. The repair will never get cheaper the more you run it.
I would put a wrench on the crank and see if it will turn? See if it has end play? See if you can turn it back and forth even a small amount? That would tell you it is a piston or other component, and not the crank. No end play in the crank means it is either the starter Jammed or the crank seized. If turning it back frees it up it could be a bearing and it will seize again.
Two people and a volt meter, will tell you a lot. Cleaning the battery posts is always a good idea, and the cheapest fix available. As is checking the crank end play. Just a thought!
Johnp3 is offline
post #4 of 5 (permalink) Old 11-29-2010, 09:53 PM Thread Starter
Thanks, unfortunately I'm not the one working on it otherwise I'd do all this. Otherwise I just get to relay this info and the owner gets to choose what he wants to do with it.
post #5 of 5 (permalink) Old 12-07-2010, 10:58 PM
Cincinnati Guy's Avatar
Use a 15/16 socket and see if the motor will turn over by hand.
FORMERLY SMOKIN85
Ryan
1994 F-350 SRW Crew Cab 4x4 Dana 60 Front, 4.10 Gears with a E4OD
SOLD-1992 F350 7.3
Ryans 92 Diesel Pictures
SOLD-1985 F250 6.9 NA
Ryans 85 Diesel Pictures
The Diesel Garage Mafia
Singles Club
Ridin' Dirty Club #24
Don't forget to vote in TOTQ
Cincinnati Guy is offline
DT466E Quit and wont crank rgreen Medium and Heavy Duty 7 07-22-2010 03:15 AM
F350 Super Duty will crank but wont start! jpeters2 1994-2003 7.3L Power Stroke 4 03-17-2008 06:36 PM
truck wont turn!! 2008TT450 Duramax 2001-2004 (LB7) 9 12-29-2007 05:16 AM
Truck wont crank rrkyle 7.3L and 6.9 IDI (Pre 1994) 4 01-24-2007 03:31 AM
Headlight wont turn off tunaluvar 1994-2003 7.3L Power Stroke 4 03-02-2006 08:22 PM
