94 IDI turbo and earlier 7.3 question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by B.L.Zbub, this thread has received 4 replies and been viewed 1556 times.
post #1 of 5 (permalink) Old 12-06-2010, 04:46 AM Thread Starter
I have a 94 F350 IDI Turbo that need an engine or rebuild. Really bad blowby to the point that I am burning as much as a gallon of oil per week and can't add oil with the engine running. (Yes, it blows that badly out of the filler neck!)
My question is can my factory turbo unit be installed on an earlier non turbo 7.3 without too much headache?
I ask because I have a line on a 1991 7.3 on the cheap and would much rather just do a swap than a rebuild right now.
Any info or advice would be greatly appreciated.
Thanks in advance.
B.L.Zbub is offline
post #2 of 5 (permalink) Old 12-06-2010, 05:13 AM
dieselguyoftx's Avatar
Yes you can put the turbo on an early model 7.3 idi. Should all just bolt up.
1995 F-350 CC Dually 4x2 7.3 power stroke bolt action
01 Dodge 2500 2wd Flatbed CTD Bolt Action Bully Dog Torque dog. with 5th gear delete kit
2007 Ford Edge wife's ride
Several Farmall Tractors
"Tractors are like tomatoes. They aren't good unless they're RED!!"
dieselguyoftx is offline
post #3 of 5 (permalink) Old 12-06-2010, 05:30 AM Thread Starter
That is the answer I was hoping for!
Gonna make my life much easier.
Thanks
B.L.Zbub is offline
post #4 of 5 (permalink) Old 12-07-2010, 10:56 PM
Cincinnati Guy's Avatar
Yup I agree, bolt on deal, it will fit on both a 6.9 and the 7.3 IDI motor all outside things are almost identical and the only changes are internal. Should be good to go!
FORMERLY SMOKIN85
Ryan
1994 F-350 SRW Crew Cab 4x4 Dana 60 Front, 4.10 Gears with a E4OD
SOLD-1992 F350 7.3
Ryans 92 Diesel Pictures
SOLD-1985 F250 6.9 NA
Ryans 85 Diesel Pictures
The Diesel Garage Mafia
Singles Club
Ridin' Dirty Club #24
Don't forget to vote in TOTQ
Cincinnati Guy is offline
post #5 of 5 (permalink) Old 12-16-2010, 05:55 AM
4play's Avatar
If I was you I would try to hang onto the IDI turbo engine and maybe rebuild it when you have time and money. The factory turbo engines were beefed up versions of the 7.3 compared to the N/A IDI. Though most people would say a N/A IDI is plenty strong for the factory turbo setup.
At least keep it until your done with the swap, there are a couple things that are different that you may not realize at first. Like the fuel lines, LH valve cover, CDR valve, glow plug harness and relay location, Trans dipstick tube (if auto). The turbo injection pump and injectors are different too but not necessary.
4play is offline
05+ suspension on earlier truck hhrecovery General Ford Truck and Excursion 10 04-24-2010 06:21 AM
turbo question 4cstr 1994-2003 7.3L Power Stroke 19 08-13-2009 08:34 PM
Turbo Question(Tech Question) Liftedpsd 2003-2007 6.0L Power Stroke 7 09-16-2007 04:35 PM
Site down earlier today??? nummit Site Information 6 07-20-2006 06:57 AM
04 and Earlier Rear Radio Controls For F-250/350 w/Captain's Chairs/Center Console Puddle Pirate Ford - Modification instructions, Product installs and Tech Articles 1 08-29-2005 09:08 PM
