89 IDI timing questions - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by dieselguyoftx, this thread has received 1 replies and been viewed 2128 times.
post #1 of 2 (permalink) Old 12-23-2010, 03:27 AM Thread Starter
dieselguyoftx's Avatar
Question 89 IDI timing questions
I'm working on a 89 IDI for a buddy he wanted me to turn up the pump. So I did now its acting up. The truck had an intermittent start problem before he bought it. He worked on it for the previous owner. Put on a elect. lift pump no more start problem. I turned up the pump and advanced the pump timing a little bit. I drove it and every thing was good had more pep. Now today I replace the valve cover gaskets and drove it again. Noticed a timing knock while on the road at steady speed so looked in to it when got back to the house. If you let it sit and idle it will start to knock like preignition knock then if you throttle it up it will almost run away then come back down to idle speed. Then does the same thing again. I think the pump is messing up. I can move the advance arm on the side of the pump and it doesn't change sound when it starts the knocking. The knock goes away after it revs up for a min then goes back to knocking again. Has any one on ever advanced the pump timing on these or is that not a good idea? I think maybe the govneror in the pump maybe messing up reason for the start problem before. but not sure.
1995 F-350 CC Dually 4x2 7.3 power stroke bolt action
01 Dodge 2500 2wd Flatbed CTD Bolt Action Bully Dog Torque dog. with 5th gear delete kit
2007 Ford Edge wife's ride
Several Farmall Tractors
"Tractors are like tomatoes. They aren't good unless they're RED!!"
dieselguyoftx is offline
post #2 of 2 (permalink) Old 12-24-2010, 12:52 AM
Cincinnati Guy's Avatar
How much did you turn the injector pump up when you advanced the timing, which direction did you do?
How much did you turn the pump up?
FORMERLY SMOKIN85
Ryan
1994 F-350 SRW Crew Cab 4x4 Dana 60 Front, 4.10 Gears with a E4OD
SOLD-1992 F350 7.3
Ryans 92 Diesel Pictures
SOLD-1985 F250 6.9 NA
Ryans 85 Diesel Pictures
The Diesel Garage Mafia
Singles Club
Ridin' Dirty Club #24
Don't forget to vote in TOTQ
Cincinnati Guy is offline
Best No timing box aballll18 5.9L Cummins (1998.5-2002) 5 07-21-2009 08:39 PM
timing? 01_24valve 5.9L Cummins (1998.5-2002) 5 07-15-2009 06:15 AM
Timing Questions JSL1990 5.9L Cummins 12 Valve (1994-1998.5) 13 05-06-2008 03:31 AM
Timing ? TheNightmare 5.9L Cummins 12 Valve (1994-1998.5) 13 04-09-2008 04:18 PM
Timing bigriggin it 7.3L and 6.9 IDI (Pre 1994) 2 09-12-2007 04:20 AM
