7.3 IDI keeps stalling - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by luc, this thread has received 2 replies and been viewed 6267 times.
post #1 of 3 (permalink) Old 02-17-2011, 04:55 AM Thread Starter
luc
Hi everyone,
I have a 1990 F250 4X4 that keeps stalling after I start it and drive it a bit. It stalls at the stop light or when I am driving. In all cases I just start it and keep going until it stalls again.
About a month ago I replaced the leaky injector caps and fule lines, voltage regulator and fuel flter\water seperator. I bled the lines of air doing one injector at a time starting from the fuel filter\water seperator and ending with #8 on drivers side. I really need to get my truck going but I am not sure what else it can be.
Thanks guys in advanced
luc is offline
post #2 of 3 (permalink) Old 02-20-2011, 02:09 PM
Cincinnati Guy's Avatar
It Could be a few different things, could be a clogged fuel filter, or faulty fuel pump. Do you have the history on when the filter was last changed? When it is running does it run good? How hard is it to restart after it stalls?
FORMERLY SMOKIN85
Ryan
1994 F-350 SRW Crew Cab 4x4 Dana 60 Front, 4.10 Gears with a E4OD
SOLD-1992 F350 7.3
Ryans 92 Diesel Pictures
SOLD-1985 F250 6.9 NA
Ryans 85 Diesel Pictures
The Diesel Garage Mafia
Singles Club
Ridin' Dirty Club #24
Don't forget to vote in TOTQ
Cincinnati Guy is offline
post #3 of 3 (permalink) Old 02-22-2011, 02:12 PM
Super Moderator
John_G's Avatar
If it stalls only after the engine is warm or hot, take a bottle of water and pour it over the IP cover, if it starts right off, the solenoid is weak.
Also, be SURE the grounds on the engine are GOOD, if you have a poorly grounded block the run solenoid doesn't pull enough amps to stay on when it heats up. Could also be in the ignition switch.
I vote for LIBERTY!
John_G is offline
03 6.0 stalling out 03lariatsd 2003-2007 6.0L Power Stroke 3 03-15-2009 11:30 PM
Stalling tjl 1994-2003 7.3L Power Stroke 3 05-05-2008 10:03 PM
HELP 6.5 stalling again josh3434 6.5L Diesel Engine 7 02-11-2008 08:05 PM
stalling rodney960 1994-2003 7.3L Chips & Tuners Forum 8 08-10-2007 05:08 AM
