6.9 ATS Turbo Loud Chirping - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by That7.3Guy, this thread has received 7 replies and been viewed 3627 times.
post #1 of 8 (permalink) Old 04-07-2011, 02:40 AM Thread Starter
I just bought an 84 f-350 6.9 idi with an ats turbo on it. From what i can tell its a non-wastegate turbo. After half throttle the ongoing chirping is crazy loud and wont stop till i let up on the pedal. It really doesn't pull very much either so i figured i have little to no boost. Unfourtunatly i dont have a boost guage. I'm not really familiar with these so let me know your thoughts...
99' F250, Crew Cab, Short Bed, 6" Lift, 37's on 18's, HID Headlights, LED Tail and Bed Lights, 5" Turbo Back,, Intake, TS 6 POS Chip
That7.3Guy is offline
post #2 of 8 (permalink) Old 04-07-2011, 03:04 AM
That make me think you could have a turbo wheel hitting the housing.
later is offline
post #3 of 8 (permalink) Old 04-07-2011, 03:07 AM Thread Starter
Hmmm. I'll check the shaft play tomorrow and see what I can find out. Thanks.
post #4 of 8 (permalink) Old 04-08-2011, 01:56 AM Thread Starter
Checked it out and there is a little play. Fired it up with the intake off and the wheel hesitated to get spinning. After a couple seconds it stayed spinning. Looking at the P/N: H730441, S/N: 011910. Thoughts?
post #5 of 8 (permalink) Old 04-08-2011, 02:34 AM
If you caught it soon enough.... you could get by with just a rebuild kit. I would pull it apart and see what the problem is, before I bought any parts.
later is offline
post #6 of 8 (permalink) Old 04-08-2011, 03:04 AM Thread Starter
I see. I've never had a turbo apart before or off the enginge for that matter. What am I looking for and how easy is it to get apart. Do i need to remove the whole turbo from the truck or just the housing? Thanks
post #7 of 8 (permalink) Old 04-08-2011, 02:49 PM
I can not say I have ever worked on a 6.9 that had a turbo, I was under the impression they all came naturally aspirated, so I am assuming it has a ATS turbo kit.
I would pull the turbo off and see what model it is, there should be tags on the center section with make, model, and so on. If the wheel on either end has hit the housing it may need to be replaced. A little rub will leave a bright spot on the housing, a hit will damage the blades.
Also it is possible that the bearings are coked up to the point they will not turn free. So check it out or get someone to check it out. If that 6.9 came from the factory as a naturally aspirated engine, you should be able to go back to that for now.
later is offline
post #8 of 8 (permalink) Old 04-21-2011, 12:55 PM
Intrailhunter's Avatar
http://www.dsmtuners.com/forums/arti...-part-1-a.html
http://www.dsmtuners.com/forums/arti...-part-2-a.html
If you have to rebuilt I use these web pages for my rebuilt. it was easy to do.
Here is some photo of my ATS turbo apart. I hope these help.
http://www.nyrocatv.com/forum.cgi?vi...c=21419&show=8
Project--1992 International School Bus Model 3700, IDI 7.3, Transmission Allison Model AT545, 94 IDI turbo, Fuel SVO
Intrailhunter is offline
Tags
6.9, ats, chirping, turbo
MBRP turbo back cat delete: Too Loud? Harcati 2003-2007 6.0L Power Stroke 11 10-23-2009 03:18 AM
Detroit -non-turbo 3-53, Loud exhaust everettapples Medium and Heavy Duty 1 04-14-2008 04:55 AM
Loud turbo whistle diesel don 5.9L Cummins 12 Valve (1994-1998.5) 2 04-24-2007 05:00 PM
will a cold air intake make my turbo loud? f_stahl 1994-2003 7.3L Power Stroke 9 02-01-2007 09:59 PM
So, you think your turbo has a loud whistle? imported_Arkapigdiesel 2003-2007 6.0L Power Stroke 17 11-16-2005 04:25 AM
