6.9/7.3 flywheel - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by marv0007, this thread has received 3 replies and been viewed 2504 times.
post #1 of 4 (permalink) Old 07-09-2011, 10:41 PM Thread Starter
6.9/7.3 flywheel
can i use a flywheel from a 7.3 a 2pice on my 6.9,,or should i use the solid one off of 6.9 thanks
marv0007 is offline
post #2 of 4 (permalink) Old 07-18-2011, 12:55 AM
Did you post on another site? It will depend I think on which tranny you are using. The 6.9 came with the 4 speed. the 7.3 with the 5 speed. You can use the 6.9 flywheel and pressure plate with the 7.3 clutch disc if it is the same size or smaller. You can use the entire set up just depends on trans.
'96 F-250 4X4 PSD some mods
'95 F-350 2X4 PSD similar to above mods
'90 F-250 4X4 with '93 7.3 N/A farm truck
'89 F-250 4X4 7.3 N/A farm truck 300,000+
'87 F-250 4X4 6.9 with Banks side winder Gearworks underdrive
'83 F-350 2X4 6.9 with 125,XXX original miles 7/11/11
540milotalon is offline
post #3 of 4 (permalink) Old 07-19-2011, 05:02 PM Thread Starter
i am running a 6.9 with a7.3 flywheel--(2 piece) with a 4 speed trans from the 6.9 is that ok thanks
marv0007 is offline
post #4 of 4 (permalink) Old 07-19-2011, 09:45 PM
I believe you will need a 6.9 clutch (small Spline) with that trans. I'm not sure if you can use a 6.9 disc with a 7.3 fly wheel and Press plate. You can do it the other way around 7.3-5 speed- large spline disc with 6.9 fly wheel and press plate. Try to find an intelligent, NAPA parts guy to help. Most parts places/persons only know how to sell kits. I currently have one 6.9 ("83) that I'm going to use the 7.3 disc with the 6.9 flywheel and pressure plate, and this is a NAPA disc. Trick here was to use a smaller diameter disc with the existing fly wheel and press plate.
The Following User Says Thank You to 540milotalon For this addition to TDG:
marv0007 (09-07-2011)
Flywheel advice jsnap Medium and Heavy Duty 10 03-11-2011 06:10 PM
6.2 flywheel question jmlloar 6.2L Diesel Engine 8 01-03-2011 02:14 AM
Flywheel 1964reo 5.9L Cummins 12 Valve (1994-1998.5) 1 12-16-2007 02:45 PM
Which flywheel 01duramax6spd 5.9L Cummins (Pre 1994) 1 09-17-2006 06:56 PM
Flywheel n2diesel Whats Been Sold 3 07-14-2006 09:23 AM
