1994 7.3 will not start - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by sleeper4036, this thread has received 4 replies and been viewed 1524 times.
post #1 of 5 (permalink) Old 07-17-2011, 02:33 AM Thread Starter
i pulled the heads off my idi 7.3 to replace the gaskets put every thing back like they were i marked the pump before pulling it off had motor on top dead center pump was at 4 o'clock position and was put back like it checked glow plugs they are good,glow plug controller is good and works right has fuel at all the lines and smokes when turning over any ideas of what it could be
sleeper4036 is offline
post #2 of 5 (permalink) Old 07-17-2011, 10:07 PM
Send a message via AIM to Dr_Diesel
Did you pull the Injection pump gear cover off for any reason? If you did chances are you moved the gear and it's out of time. The pump will only go in one way the gear cant move with the cover left on. Check through the threads their is one on how to check the gear timing without pullings the front cover off the engine. It's a little tricky but it works.
Dr_Diesel is offline
post #3 of 5 (permalink) Old 07-18-2011, 03:43 AM Thread Starter
Yes I pulled it off it made more room for everything I didn't know I was not suppose to pull it off my mistake but I have read some of threads line the y with the o with motor on top dead center ill try that tommorow afternoon when I get off thanks a lot for the info
post #4 of 5 (permalink) Old 07-18-2011, 01:51 PM
Super Moderator
John_G's Avatar
Yup, a tooth off is a mile off
After my first frusterating experience with this, I figured out how to do HGs (6.9L) w/o removing the belly-pan, sorta crude but it works and if I absolutely have to remove the IP, it comes off complete with the cover after the timing is marked on the crank and IP gear cover!
I vote for LIBERTY!
John_G is offline
post #5 of 5 (permalink) Old 07-19-2011, 02:16 AM Thread Starter
well when it rains it pours i read one on the timing with a glass and light well i got the o up and the glass fell down in the motor what a day im try one of those claw tools to get it out if it dont work ill pull the front down
truck started fine in the morning now it will not start!!! 1994 powerstroke diesel tbo79 1994-2003 7.3L Power Stroke 9 12-25-2010 05:21 AM
1994 7.3 turbo will not start tbo79 1994-2003 7.3L Power Stroke 1 12-15-2010 05:42 PM
1994 Suburban 6.5 won't start, weak injector pressure. CaveCreekAZ 6.5L Diesel Engine 0 11-18-2010 06:10 PM
Strange Cold start/no start/start changexlt 2003-2007 6.0L Power Stroke 7 12-23-2008 10:00 PM
1994 Cummins Hard Start story & questions ash_flat_diesel 5.9L Cummins 12 Valve (1994-1998.5) 6 03-12-2007 03:34 AM
