7.3 idi non turbo - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Bigdog2317, this thread has received 2 replies and been viewed 3251 times.
post #1 of 3 (permalink) Old 07-20-2011, 04:12 PM Thread Starter
7.3 idi non turbo
I just bought a 1994 ford van with a 7.3 idi diesel non turbo and would like to know what kind of performance upgrades are available for it as it does not run as good as my 1996 ford with the turbo powerstroke all suggestions would be appreciated thanks,brian
Bigdog2317 is offline
post #2 of 3 (permalink) Old 07-20-2011, 05:58 PM
4cstr's Avatar
Images: 35
Hi Bigdog...and welcome to TDG.
I moved your post into the Ford forum where it will be hopefully seen by more Ford gurus.
~Dave~
4cstr is offline
post #3 of 3 (permalink) Old 07-21-2011, 02:00 AM
Intrailhunter's Avatar
You will need to spend money to make some power. First you need a Turbo and then an IC then you can turn up the pump. But get all the gauges to protect the money on the cost to make some power.
Iím getting 11PSI boost and Exhaust temp is hitting 900* and I can turn it up some more but 1000-1100* is all I want to be safe.
Project--1992 International School Bus Model 3700, IDI 7.3, Transmission Allison Model AT545, 94 IDI turbo, Fuel SVO
Intrailhunter is offline
Turbo non Turbo parts swap trucknut6657 6.5L Diesel Engine 6 03-26-2011 04:44 PM
Isspro Turbo monitor or Turbo timer proud1 1994-2003 7.3L Power Stroke 4 03-12-2010 12:46 AM
1991 Ford 7.3 Non Turbo I Need To Figure Out How To Turbo It blacksmokeobs 7.3L and 6.9 IDI (Pre 1994) 7 04-01-2009 01:51 AM
Wanted: Early 99 PSD Turbo Pedistal with or without turbo. WyoDieselCowboy Whats Been Sold 3 04-22-2007 10:20 PM
Very oily tube post turbo. Means Bad turbo seals? I10HaulR 2003-2007 6.0L Power Stroke 1 03-07-2007 11:59 PM
