1990 f250 strange probs help - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by msckksm, this thread has received 2 replies and been viewed 777 times.
post #1 of 3 (permalink) Old 08-02-2011, 06:56 PM Thread Starter
I have a 1990 f250 diesel, the oil pressure gauge drops to zero when the check engine dummy lght comes on and i also notice the rpm gauge does not stay up it drops to zero as well . What is going on?
msckksm is offline
post #2 of 3 (permalink) Old 08-03-2011, 03:44 AM
Super Moderator
John_G's Avatar
Either the cluster feed or ground are more than likely not working correctly.
FYI, you don't have an oil pressure "gauge", you have a swtich and a light with a needle and the letters "NORMAL" on it.... either it shows OP or it does not there is no variation in what it shows.
I vote for LIBERTY!
John_G is offline
post #3 of 3 (permalink) Old 08-03-2011, 04:15 PM
Usually the tach problem is the tach sensor located on the injector pump gear cover,will probably need replacing.The oil pressure problem my just be the sender.First do an oil pressure check with a gauge(the engine needs to be hot and idling at a min of 750 rpm).The oil pressure needs to be a min of 10 psi to keep the gauge reading in the normal area.good luck.
bronco1
bronco1 is offline
1990 f250 steering issues 99_stroker 7.3L and 6.9 IDI (Pre 1994) 2 03-02-2010 05:38 PM
Lights and ac probs Haus720 General Dodge Discussion 2 10-13-2009 08:58 PM
parting out 1990 f250 diesel 4x4 5 speed imported_machine2 Whats Been Sold 2 05-29-2007 02:33 AM
Funny probs with my new 6.5 vtveggiburb 6.5L Diesel Engine 10 03-31-2007 10:53 PM
91 F-250 303 5spd probs StrokerAce General Gas Vehicle 3 10-20-2006 04:44 AM
