1993 7.3L throttle adjustment...Maybe? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jlarrabee, this thread has received 1 replies and been viewed 2713 times.
post #1 of 2 (permalink) Old 08-27-2011, 05:26 PM Thread Starter
Just had replaced: Fuel injectors, injection pump, fuel pump, pickup pump, gas tank switch, and batteries and cables. All this was done and now the beastie will start and doesn't smoke! However, even though it does have enough pick up and go it seems like the throttle cable is too long (?) I always seem to have the accelerator to the floor while driving. It's a manual transmission and driving through a hilly section on the drive home from the shop it seems happy and wants to go - I just can't give it the fuel to do so. Am I silly in this theory. Yes, I am a girl!
jlarrabee is offline
post #2 of 2 (permalink) Old 08-27-2011, 07:42 PM
Super Moderator
John_G's Avatar
The accelerator cable should be tight and the "overtravel" linkage should be displaced to the rear of center about 1/8" with the pedal hard against the floor (bricks and sticks work). The "high idle" stop should be contacting the fuel lever in this condition as well, if not you can bend the cable mounting bracket rearward to achieve contact.
There really is not an adjustement to the cable, but the bracket it mounts to can become bent, preventing you from reaching full fuel.
I vote for LIBERTY!
John_G is offline
The Following User Says Thank You to John_G For this addition to TDG:
jlarrabee (08-27-2011)
Tags
7.3, throttle
1993 silverado 6.5 1993 silverado 6.5 turbo 6.5L Diesel Engine 1 10-15-2010 05:25 PM
need 1993 5.9 engine JEEPSTER401 5.9L Cummins (Pre 1994) 1 04-18-2010 06:28 PM
Clean 1993 ram ext. cab drw 2wd StrokerAce Whats Been Sold 0 02-18-2009 10:30 PM
1993 F250 TPS adjustment?? crazycracker 7.3L and 6.9 IDI (Pre 1994) 4 11-19-2007 05:49 PM
Can someone please walk me through a Throttle Valve Adjustment Strictly gravy 5.9L Cummins (1998.5-2002) 4 11-03-2007 06:12 AM
