7.3 idi smoking under back pressure - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Mike444z, this thread has received 2 replies and been viewed 1765 times.
post #1 of 3 (permalink) Old 10-20-2011, 10:47 PM Thread Starter
I have a 94 7.3 idi turbo diesel with stock exhaust that when its under back pressure from the engine, like when coming down a hill and let off accelerator or get back on it will have a smoke cloud coming out the exhaust. It is not burning any oil. I was wondering if anyone had any ideas of what might be the problem? Thanks
Mike444z is offline
post #2 of 3 (permalink) Old 01-11-2012, 12:46 PM
Ky. horseman's Avatar
Sounds very normal to me,DIESEL,SMOKE!
Ky. horseman is offline
post #3 of 3 (permalink) Old 03-15-2012, 04:53 PM
Using an engine for breaking should not produce a lot of smoke. The first time I read this, it did not click. When an engine is used for engine breaking it can draw oil past worn valve seals. On a gas engine it is visible on the first start of the day, and in many cases is visible while coming to a stop while coast against the engine. If the engine has a worn oil control ring it will smoke under acceleration. Some of these symptoms will be masked on a diesel because they smoke anyway, but smoke while decelerating against engine compression may not be normal. Is it a real smoke cloud?
courtem is offline
back pressure Quantum 2008-2010 6.4L Engine Tuner Forum 10 03-31-2010 03:59 AM
Back pressure? carvinmark 1994-2003 7.3L Power Stroke 4 08-30-2007 01:31 AM
back pressure dustin 08 General Gas Vehicle 2 07-22-2007 04:13 AM
back pressure question dustin 08 5.9L Cummins (1998.5-2002) 5 07-22-2007 12:17 AM
Back pressure Cummins_47re 5.9L Cummins (1998.5-2002) 3 05-07-2007 01:56 AM
