MANUAL GLOW PLUG CONTROLLER SAVE$$$ ON GLOWPLUGS - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Ky. horseman, this thread has received 8 replies and been viewed 18124 times.
post #1 of 9 (permalink) Old 01-03-2012, 07:51 PM Thread Starter
Ky. horseman's Avatar
Thumbs up MANUAL GLOW PLUG CONTROLLER SAVE$$$ ON GLOWPLUGS
ONCE AGAIN IT'S TURNING COLD AND I'M SEEING POSTS ABOUT HARD TO START AND GLOW PLUG ISSUES.I'VE BEEN THERE AND HAD THE SAME PROBLEMS AS SOME OF YOU OTHERS.WELL I FOUND SOMETHING THAT HAS WORKED GREAT FOR ME AND SAVED $$$$ ON GLOW PLUGS,IT'S A MANUAL CONTROLLER FOR THE GLOW PLUGS,GIVES ME CONTROL OF WHEN THEY ENERGIZE,SO THEY DONT CYCLE EVERY TIME I START THE TRUCK,ONLY WHEN I ENERGIZE VIA A PUSH BUTTON SWITCH,OK I'LL QUIT TALKING AND POST THE INFO. GO TO EBAY MOTORS TYPE IN ITEM#320800599383 INTO THE SEARCH BOX HOPE THIS WILL HELP SOME GUYS OUT.
Ky. horseman is offline
post #2 of 9 (permalink) Old 01-04-2012, 05:06 AM
hayjayhorses's Avatar
I sent the Ebay seller this
"I have set up "push button GP relays" on several trucks. They all work very well except on the 7.3 IDI engines, I kept burning up the glow plugs.
I got the issue figured out. The 7.3 IDI (bullet connector) GPs are 5 volt (6 volt system) that is why there a resistor on the GP controller.
The solution is to use 6.9 (blade connector) GPs are 12 volt, and are the same size as the 7.3 IDI GP.
http://www.dieselrxproducts.com makes a dual coil 6.9 IDI glow plug that I use in my 7.3 IDI trucks and they work very well."
Jay Noone
413-222-8286
I got hay
Vote Ron Paul 2012
hayjayhorses is offline
post #3 of 9 (permalink) Old 01-17-2012, 12:00 AM
jrod1986's Avatar
so would putting is a ballast resistor have the same effect as the glow plug controller for the 7.3's? when i did my motor swap i left the 6.9 harness in and switched all the connectors cuz i thought the 7.3 gp's were supposed to be better.
86 F-250 4X4..7.3 non turbo from an 89.. E injectors and pump turned up.. 4 speed..3.55 gears.. new dual 4" exhaust by diamond eye-- with the muffler > for now!
jrod1986 is offline
post #4 of 9 (permalink) Old 01-17-2012, 07:19 PM
I don't know how a ballast resistor works. The 7.3 IDI GP get hot much faster.
Jay Noone
413-222-8286
I got hay
Vote Ron Paul 2012
post #5 of 9 (permalink) Old 01-17-2012, 09:33 PM Thread Starter
I put the glow plug relay off ebay in my truck 2years ago,and wired it per the instructions,and i've had no problems at all,you hold glowplugs energized for no more than 10 seconds,i'm still running same glow plugs as when i put it in,i'm interested in the wellman 2 coil glowplugs,for the next time,
post #6 of 9 (permalink) Old 01-18-2012, 04:51 PM
jrod1986's Avatar
i am not running any of the gp controllers, 6.9 or 7.3. i just have it wired from the relay to the switch to the gps. i hold for a 10 count and let off, start cranking on the starter while holding the switch again for 10. truck usually starts right up doing that. though i noticed it doesn't fire as quickly as it did last year when they were new. hope i didn't fry them by not having a resistor.
- a ballast resistor works by taking the voltage from 12 down to i dunno what. they were used on old cars and trucks to lessen the voltage going to the coil.
jrod1986 is offline
post #7 of 9 (permalink) Old 01-19-2012, 07:08 PM Thread Starter
Couldn't quite remember,so i checked on mine,it's on a manual switch,but it still uses the glowplug controller to control the voltage,which is at 9volts.
post #8 of 9 (permalink) Old 01-28-2012, 10:52 PM
Super Moderator
John_G's Avatar
There is no GP system on these that uses current limiting (a resistor) to keep the GPs alive. That big squiggly bar is more of a buss-bar than a resistor.
The 6V GPs are alive because they are NOT CONTINUALLY ON, but are cycled.
Guys, the GP system in our '93 is FACTORY, 19 years and only ONE set of GPs and one relay. You are not likely to "engineer" anything better or more reliable.
There are two real keys to longevity of the GP systems, neither are voodoo:
1) Use OEM parts
2) Know HOW it is supposed to work and keep it that way
I vote for LIBERTY!
John_G is offline
post #9 of 9 (permalink) Old 02-06-2012, 02:21 PM
When I use the manual bypass switch for the glow plugs I have great results. My wife and daughter tho fried new Beru plugs in 2 months. I went back to the stock controller but they sell them solid state now. It actually works better than the bypass switch IMHO. Cold or hot the truck fires right up. Never any extra cycles or needing to cycle it twice. $70 has made it too easy even when single digits to start my truck. I did leave the bypass switch installed just in case.
mtnsammy is offline
Manual glow plug question ParkerFly 1994-2003 7.3L Power Stroke 7 04-16-2009 06:39 PM
Pinout for glow plug controller? Bluevanacd2005 7.3L and 6.9 IDI (Pre 1994) 6 04-22-2008 03:40 AM
83 to 85+ Glow Plug Controller Swap question. ordiesel 6.2L Diesel Engine 5 10-10-2007 04:42 AM
Glow plug controller on 6.2 moses 6.2L Diesel Engine 8 02-04-2007 02:13 PM
need some glow plug and a controller..... triton Supporting Vendors Forum 3 01-29-2007 04:28 PM
