93 sometimes won't starts? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by trapper24-7, this thread has received 4 replies and been viewed 2047 times.
post #1 of 5 (permalink) Old 03-21-2012, 07:35 PM Thread Starter
Send a message via AIM to trapper24-7
Unhappy 93 sometimes won't starts?
I have a 93 7.3idi turbo. It will start fine most the time but sometime when i go to the store or something and its sits for like 5-10 mins and i come out it won't fire. It shouldn't be the glow plugs because the truck is still hot. After it starts it runs great, i have power and everything runs good sounds good but it just will not fire sometime... it seems like it starts better when its cold then when its warmed up. Anybody know what that might be? thanks
trapper24-7 is offline
post #2 of 5 (permalink) Old 03-29-2012, 12:14 AM
bmoeller's Avatar
Could be that the shutdown solenoid on the fuel injection pump going bad. They can get heat soaked and not work when they get old.
Never had it happen the the '86 I used to have, but seen it happen on others.
If it runs rough at all when it does eventually start, you could have an air leak in the fuel system. Won't always leak fuel when it happens either.
"Obama = Hoax and Chains"
bmoeller is offline
post #3 of 5 (permalink) Old 04-16-2012, 02:24 PM
Ky. horseman's Avatar
What bmoeller said.
89 F250 HD 7.3L IDI E4OD TRANNY 4IN" EXHAUST WITH FLOWMASTER 40 SERIES PUMP TURNED UP 1 FLAT SOUP BOWL MOD HOMEMADE AIR INTAKE B&M SHIFTKIT,MANUAL TQ CONV LOCKUP MANUAL GP SWITCH BILLET GRILLE,DRIVING LIGHTS IN BUMPER LED CAB LIGHTS,20% TINTED WINDOWS GOOSENECK AND RECEIVER HITCHES
FUEL TANK VENT MOD
MOSTLY HAULIN HAY AND HORSES 24,000lb.GVW TRANNY COOLER WITH FAN
Ky. horseman is offline
post #4 of 5 (permalink) Old 10-18-2012, 08:15 PM
spanky63
Won't Start
The reason your truck is not starting when it is warm is because your starter is dragging. Make sure your batteries are in good shape (have them tested) then pull your starter and get it tested. I had the same problem and I finally replaced the starter ow it fires like a dream. It doesn't take much drag for the engine not to turn over. But when it is already warm it has to be the starter dragging.
Spanky636569 is offline
post #5 of 5 (permalink) Old 04-07-2013, 04:39 AM
Did you get this straightened out?
'96 F-250 4X4 PSD some mods
'95 F-350 2X4 PSD similar to above mods
'90 F-250 4X4 with '93 7.3 N/A farm truck
'89 F-250 4X4 7.3 N/A farm truck 300,000+
'87 F-250 4X4 6.9 with Banks side winder Gearworks underdrive
'83 F-350 2X4 6.9 with 125,XXX original miles 7/11/11
540milotalon is offline
'87 6.9L IDI Starts, dies, then starts after cranking trbopumper 7.3L and 6.9 IDI (Pre 1994) 4 10-18-2010 02:51 AM
Ether starts Fireguy 5.9L Cummins 12 Valve (1994-1998.5) 5 11-10-2007 12:55 AM
starts only when it wants dwilder 6.5L Diesel Engine 2 07-28-2007 04:56 PM
It Starts crzycowboy The Parking Lot 11 08-11-2006 03:15 PM
So it starts Fantom3993 2003-2007 6.0L Power Stroke 13 09-05-2005 06:12 PM
