'86 6.9 w/ Banks Turbo low power... - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Twilight Fenrir, this thread has received 2 replies and been viewed 1599 times.
post #1 of 3 (permalink) Old 09-15-2012, 03:21 AM Thread Starter
I just bought an '86 F250 with a 6.9L diesel, with the banks turbo kit. It just seems to be alot slower than I would expect, and I'm trying to find out if something is wrong. I'm not expecting the truck to break any land speed records here, but I have to stomp on it to get up to speed, and the pedal is almost completely against the floor while cruising at 60 mph.
I've cleaned out the air filter, and replaced the fuel filter. I pulled off the turbo intake and tried to wiggle the fan, and it's nice and snug with no sign of bearing wear, and spins freely.
I'm not really sure what else to check. It was suggested that I need to check my fuel injectors, and the injector pump... but I'm not really sure how to go about either. Any advice?
Thanks.
Twilight Fenrir is offline
post #2 of 3 (permalink) Old 03-26-2013, 01:13 AM
Do you have a Exhaust Temp gauge? If so it so like you could crank up the fuel some. do a search on here on how to safely do it. One flat at a time. I know people running around 950-1140* with no problems noted. Maybe someone else will disagree.
'96 F-250 4X4 PSD some mods
'95 F-350 2X4 PSD similar to above mods
'90 F-250 4X4 with '93 7.3 N/A farm truck
'89 F-250 4X4 7.3 N/A farm truck 300,000+
'87 F-250 4X4 6.9 with Banks side winder Gearworks underdrive
'83 F-350 2X4 6.9 with 125,XXX original miles 7/11/11
540milotalon is offline
post #3 of 3 (permalink) Old 03-26-2013, 02:44 AM
The 6.9 ain't gonna punch a hole in the wind, but it should dobetter than you're saying. Like 540 said, if it is not black smoking when you are hard into it, it could do more . However, when it does blow black, you need to back out a little. If the exaust is black as coal, your wasting fuel. Also you can advance your pump just a bit. Good luck.---Bob One more thought. Your waste gate may be partially stuck open.---Bob
broncobob is offline
Banks power PDA powerstroke7.3 2003-2007 6.0L Power Stroke 7 08-04-2009 03:48 AM
Banks Power Cummins_47re 5.9L Cummins (2003-2007.5) 30 05-27-2007 07:00 PM
Ball Bearing Turbo w Banks Power Elbow BIGRPOWR Whats Been Sold 1 06-14-2006 07:29 PM
Banks power? diesel_ram_man 5.9L Cummins (2003-2007.5) 4 06-12-2006 01:59 AM
