1992 D250 interior electrical problems - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by tommu, this thread has received 1 replies and been viewed 791 times.
post #1 of 2 (permalink) Old 05-07-2013, 06:32 PM Thread Starter
Hi, Thanks in advance. What's the easiest way to pull the stock radio from a 1992 D250 diesel. Mine radio had quit working (But I had a consonant slight amperage pull running the battery down over two,three nights sitting- so I disconnected the neg. battery terminal, use a test light from a fender screw to the neg. battery terminal= test light glowed, so I figured a positive was grounding somewhere- pulled the radio,interior light,etc. fuse= no glowing,no amperage pull . Later I replaced the fuse = no glowing,no amperage pull.) I said what the hell and pulled the fuse anyway. I could use the radio covey hole for storage. Your thoughts greatly appreciated.
tommu is offline
post #2 of 2 (permalink) Old 06-04-2013, 02:57 AM
weird member
doob51's Avatar
I pulled all the molding off my dash to get to it. I cant remember but I think there was two bolts holding the radio in . I got a plug in wire harness from ******* and crimped it to the pioneer . It slid in nice and I put the dash molding back on. If you break the molding it will super glue back together. You might find a youtube video on it.
1994 FORD F-350 4 DOOR XLT 7.3 IDI TURBO DIESEL 3INCH DOWNPIPE 4INCH STRAIGHT PIPE NON-POWERSTROKE 107K BLACK DIESEL BURNER
doob51 is offline
1992 D250 interior electrical problems tommu 5.9L Cummins 12 Valve (1994-1998.5) 2 05-10-2013 04:46 AM
electrical problems stroke this 2003-2007 6.0L Power Stroke 6 06-01-2009 03:39 AM
Electrical problems Heavyduty350 1994-2003 7.3L Power Stroke 1 04-25-2009 04:10 PM
Electrical Problems GOFASORGOBROK 2003-2007 6.0L Power Stroke 3 10-17-2007 12:55 PM
Electrical problems/dash problems curtis2003 5.9L Cummins (2003-2007.5) 1 10-21-2006 09:27 AM
