93 turbo - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by hobbieman, this thread has received 4 replies and been viewed 741 times.
post #1 of 5 (permalink) Old 02-17-2014, 12:26 PM Thread Starter
Diesel Maniac
93 turbo
I just bought two f350's 93 and 96 for parts. Can I put a 96 turbo on a 93 7.3 without the use of a PCM?
Thanks
hobbieman is offline
post #2 of 5 (permalink) Old 02-17-2014, 02:59 PM
Old Fart
dbennett48's Avatar
You can, but it won't be smooth. I turbo'd a gas 400 using some kit I bought new. I had to fab a lot of it as it was not a complete kit. I added a wastegate when I saw the boost gauge go past 15 psi, I think. It was not very smooth but it did the basic stuff - more power. Without the pcm, your truck will be rather crude in controlling the boost. Banks had a kit for the '93 at one time.
Dave
Completely Stock.
KK6TNI - HAM Radio
dbennett48 is offline
The Following User Says Thank You to dbennett48 For this addition to TDG:
hobbieman (02-17-2014)
post #3 of 5 (permalink) Old 02-17-2014, 03:06 PM Thread Starter
Diesel Maniac
Thanks I will keep that in mind, just takes a few minutes to remove and replace. I am going to do some testing. The 1996 I am take in off is an upgraded aftermarket, so we will see..
post #4 of 5 (permalink) Old 02-17-2014, 03:17 PM
Aimless Wanderer
I installed a couple of the Banks' kits, and several of the ATS conversions of which I liked better. The Banks setup worked very well but was not as linear in drivability as was the ATS system. Also the ATS was complete out of the box, (so to speak) where Banks' at the time had a bunch to pick and choose from. The ATS system was about $900.00 less expensive also.
That engine would really wake up when modified over stock correctly and not destroy itself.
The question I seek an answer for is simply; why, or why not?
Backslap is offline
The Following User Says Thank You to Backslap For this addition to TDG:
post #5 of 5 (permalink) Old 02-17-2014, 03:19 PM Thread Starter
Diesel Maniac
I will keep that in mind, thanks very much
precision turbo or garret gpt38r turbo n2diesel 1994-2003 7.3L Power Stroke 3 12-05-2011 12:28 AM
7.3 turbo wanted for 1991 pre turbo rwbmaine Whats Been Sold 0 05-24-2009 11:45 PM
1991 Ford 7.3 Non Turbo I Need To Figure Out How To Turbo It blacksmokeobs 7.3L and 6.9 IDI (Pre 1994) 7 04-01-2009 01:51 AM
Wanted: Early 99 PSD Turbo Pedistal with or without turbo. WyoDieselCowboy Whats Been Sold 3 04-22-2007 10:20 PM
Very oily tube post turbo. Means Bad turbo seals? I10HaulR 2003-2007 6.0L Power Stroke 1 03-07-2007 11:59 PM
