1990 f250 7.3 e4od - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by snowman_w900, this thread has received 3 replies and been viewed 778 times.
post #1 of 4 (permalink) Old 02-05-2017, 06:32 PM Thread Starter
snowman_w900's Avatar
1990 f250 7.3 e4od
Hey guys. Just wondered if anyone can help me answer this.
Im upgrading my old 1990 7.3 2wd E4OD due to slipping and being original. Problem is, the Speedo is cable driven. The output shaft on the newer E4OD 1994 does not have the spot for a gear. Its got the cable mounting hole, but the output shaft wont work with my speedo cable drive gear. The truck this came out of obviously had an electronic Speedo in the dash.
Question, whats my options and has anyone ran into this problem, any suggestions? Thanks guys!!!
snowman_w900 is offline
post #2 of 4 (permalink) Old 02-06-2017, 02:41 PM
Jasong's Avatar
I don't really know anything about this truck but I would change to the electronic speedometer.
That hole is probably for the electric pickup.
Jasong is offline
post #3 of 4 (permalink) Old 02-06-2017, 03:06 PM Thread Starter
Ive never changed one over to electronic, but i would love to do that. Wonder how hard that would be? It would make my situation wayyyyy easier.
post #4 of 4 (permalink) Old 02-08-2017, 03:14 AM
Jasong's Avatar
Do you have access to the donor truck? Check if that was the sender or did I use a sender on a front hub.
Can you move the speedometer over?
Should only be 4 wires.
12v
Ground
Dash lights
Signal to sender.
The sender gets 2 or three
Signal
12v
Ground (maybe)
Jasong is offline
1990 f250 strange probs help msckksm 7.3L and 6.9 IDI (Pre 1994) 2 08-03-2011 04:15 PM
1990 f250 steering issues 99_stroker 7.3L and 6.9 IDI (Pre 1994) 2 03-02-2010 05:38 PM
1990 7.3 dumptruck jimford 7.3L and 6.9 IDI (Pre 1994) 5 11-20-2007 02:34 PM
parting out 1990 f250 diesel 4x4 5 speed imported_machine2 Whats Been Sold 2 05-29-2007 02:33 AM
will a f250 gas e4od tranny work for the 7.3? broadheadjohn General Ford Truck and Excursion 2 01-20-2007 07:47 PM
