They grow up so quick - Another inch taller - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by TxFireman1972, this thread has received 5 replies and been viewed 1420 times.
post #1 of 6 (permalink) Old 06-27-2010, 07:56 PM Thread Starter
TxFireman1972's Avatar
Went ahead and went up another inch while I was doing my spring conversion. I added a 1" TEI spacer on the front for a total of 8", and went up to 9" of lift in the rear. I definitely like the stance better now. I should also have zero rub now. I'm not much on the stuffed look, I like plenty of clearance.
2005 F350 Crew Cab 4x4
PMF Rear Leaf Spring Conversion w/2011 Leaf Springs
20" Harley Wheels 305/55/20 Nitto Terra Grapplers
ARP Studs & EGR Delete from PowerStrokeMagic w/GearHead Tunes
Amp Research Steps, MBRP
TxFireman1972 is offline
post #2 of 6 (permalink) Old 06-28-2010, 01:49 AM
vrsc's Avatar
Images: 47
looks great man, how you liking your Iphone4? I saw some of your post on icafe. I love mine
2011 F250 Golden Bronze/Arizona Beige Fully Loaded King Ranch FX4, Chrome Package, 6.7 PSD, 4x4 E-Locker, 3.55, Color Matched Line-x Bed and toolbox
Icon Vehicle Dynamics/ One Up Offroad Suspension Lift
Icon Vehicle Dynamics 7"-9" Box Kit and Coil Springs
OUO ALA One Up Offroad Adjustable Link Arms
OUO Traction Bars One Up Offroad Adaptable Traction Bars
OUO Traction Block One Up Offroad Traction Block Kit - 8" w/Bump Stops - 5 Degree
OUO Position Adjustable Flex U-bolt Top Plates
OUO U-Bolts One Up Offroad 3/4" U-Bolt Kit
Icon Signature Series Shocks (3M clear film protected)
Icon Vehicle Dynamics Dual Steering Stabilizer Kit(3M clear film protected)
BMF Novakaine 8 Chrome 20x10
Toyo M/T 37x13.50x20
Color matched Brake Calipers, Amp Research Steps
H+S Mini, CAT/DPF/EGR delete, AFE intake
Ford Factory Navigation
JL Audio Clean Sweep, JL Audio HD900/5
Focal 165 KRX2 in front with TNK Tweeters
Focal 165 KR2 in back with TNK Tweeters
JL Audio 13TW5 in an spl2K box behind rear seat
JL Audio 0/Gauge Amp kit, JL Audio 4 channel RCA's
Dynamat Extreme Deadened Front Doors, Rear Wall and Doors
vrsc is offline
post #3 of 6 (permalink) Old 06-30-2010, 03:43 AM Thread Starter
OK, I added another 1" of block to the rear. I think it looks alot better. Let me know what you think.
Before adding the 1" Block:
After adding the 1" block:
post #4 of 6 (permalink) Old 06-30-2010, 03:54 AM
TDG Official Poo Flinger
TANK'S 250's Avatar
Images: 38
Better...now it doesn't look like it had a loaded diaper....
____________________________
Special thanks to:
TrustedPerformance.com
KLMperformance.com
Black Ops Bumpers
FarmboyFabrications.com
TANK'S 250 is offline
post #5 of 6 (permalink) Old 06-30-2010, 11:36 AM
bootcamp's Avatar
Fireman how do you like that Icon 4-link kit???
USMC 87-90 MOTOR-T
Build Date 01/05 05 F250 4x4 swb cc lariat
SCT XCAL3 Tune by DFuser,fluid damper,MBRP exhaust-no kitty, crossover fuel line, Coolant filter, CFM Intake elbow, Pro Comp 6" stage 2 lift and traction bars,ccv reroute, Gauges-trans,pyro,fuel,bbreg mod, B&W goose neck and companion hitch, firestone airbags, Earls anplumbing-6 hose and fittings to upgrade fuel lines,T/P stage I fuel line kit,Welded up pipe and welded egr cooler install, 4.10 yukon gears, ceramic coated manifolds install with new head gaskets and ARP's, PML trans pan, AEM brute air filter, AirDogII 165 sucking it straight off the bottom of the tank with Hellmans sump and Strictly Diesel RR kit
2010 Honda VFR1200 for when I really want to go FAST My newest collection to the armada, 2004 VW R32 and its all wheel drive
SINGLES CLUB MEMBER #259
bootcamp is offline
post #6 of 6 (permalink) Old 06-30-2010, 12:40 PM Thread Starter
Exactly!!!
Love it!! made the truck drive much better.
Change to a taller gear volwing 2008-2010 6.4L Power Stroke 1 03-31-2008 04:45 PM
Here We Grow Again! fordt Site Information 16 02-02-2008 04:52 AM
can I add a 1 inch taller block in the rear with stock shocks? morepower02 General Ford Truck and Excursion 11 11-28-2007 09:55 PM
Going a little taller BeauxPete General Ford Truck and Excursion 8 08-19-2007 07:30 AM
J.D. Power and Associates Say Diesel Vehicle Market Share to Grow wideopen General Diesel 0 07-06-2005 12:51 PM
