Valve Stems Differences - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by bootcamp, this thread has received 7 replies and been viewed 1021 times.
post #1 of 8 (permalink) Old 06-28-2010, 10:10 PM Thread Starter
bootcamp's Avatar
This was kind of interesting and maybe i am the last one to find out but how many of you new their was a difference in valve stems??? The reason I say this is because when I have new set of tires and wheels put together for me at one of the local tire dealers i assume they are putting in the correct valve stem for the tire load range application.
One of the guys I work with had a tire blow out on the rear of his truck and took that tire to a Firestone dealer and was told that the stem blew out due to it was a incorrect air pressure rated stem. it was the firestone dealer that told him who ever install the tires install the incorrect valve stems. The stems that were put on his wheels were only rated for 65 psi max and plus what he found was that the other three were dry roting. The original tire shop did not know that they were using incorrect stems and theres no telling how many 3/4 ton and 1 ton trucks that this one shop alone has put the wrong stems on. Dont assume that the tire shop you trust with your life and your family's life knows what they are doing. do a goggle and take a look at the number of law suits their are for incorrect valve stem usage. should have put some attachments, but was in a hurry.
Later Paul
Sorry for rambling and hope this makes since.
USMC 87-90 MOTOR-T
Build Date 01/05 05 F250 4x4 swb cc lariat
SCT XCAL3 Tune by DFuser,fluid damper,MBRP exhaust-no kitty, crossover fuel line, Coolant filter, CFM Intake elbow, Pro Comp 6" stage 2 lift and traction bars,ccv reroute, Gauges-trans,pyro,fuel,bbreg mod, B&W goose neck and companion hitch, firestone airbags, Earls anplumbing-6 hose and fittings to upgrade fuel lines,T/P stage I fuel line kit,Welded up pipe and welded egr cooler install, 4.10 yukon gears, ceramic coated manifolds install with new head gaskets and ARP's, PML trans pan, AEM brute air filter, AirDogII 165 sucking it straight off the bottom of the tank with Hellmans sump and Strictly Diesel RR kit
2010 Honda VFR1200 for when I really want to go FAST My newest collection to the armada, 2004 VW R32 and its all wheel drive
SINGLES CLUB MEMBER #259
bootcamp is offline
The Following User Says Thank You to bootcamp For this addition to TDG:
BillsFan (06-29-2010)
post #2 of 8 (permalink) Old 06-28-2010, 11:50 PM
Yup there is a differance. quite a price differance to
2006 yamaha Vmax
2003 suzuki 1000 GSX-R
1993 F-250 460
Near GP alberta.
CC#58
budtoh3zo is offline
post #3 of 8 (permalink) Old 06-29-2010, 04:10 PM
BillsFan's Avatar
I didn't know that either, good info, thanks for the heads up!
and Bob @ DieselSite!
TDG Singles Club Member #73
Ridin' Dirty #64
BillsFan is offline
post #4 of 8 (permalink) Old 06-29-2010, 05:21 PM
Banned
Never gave it any thought, thanks.
wastedwagesracing is offline
post #5 of 8 (permalink) Old 06-30-2010, 11:41 AM Thread Starter
bootcamp's Avatar
Check out this web site it was very interesting info...
http://techno-fandom.org/~hobbit/cars/valvestem/
USMC 87-90 MOTOR-T
bootcamp is offline
post #6 of 8 (permalink) Old 06-30-2010, 01:20 PM
Another day in paradise
nevrknow's Avatar
I made that a sticky in my head. I did not know that info.
Thanks for the heads-up!
2002 f250 4x4 SRW, 7.3L Auto, 4" exhaust, 20" rims on Toyo MT's, Boost, Pyro, Tranny ISSPRO ev's underdash pod., DP TUNER F5, stock, 60 tow, 80 , 120 race, DYI Tymar Intake
2000 New Holland 3930 Diesel tractor
nevrknow is offline
post #7 of 8 (permalink) Old 07-07-2010, 08:37 PM
Trip's Avatar
I have had a valve stem fail on me 3 years ago. After getting off the freeway and doing some back road carving to bypass the traffic I stopped at a red light in front of a Americas tire co. and within 5 seconds my right rear tire went flat I heard the stem fail and my 33in tire on my Toyota truck was flat so i limped it to atc and had them check it out thinking that my tire plug had blown out from the heat (107F outside) and pressure they came back telling me nope just your stem failed ever since then I only run clamp in valves with the retaining nut like these! while my tire was getting fixed and I waited to start my shift a my second job I thought about how if my stem would have let go ten min. earlier I would have spun out on Patterson pass road a one way strip of pavement though the hills and canyons of the altamont pass I could have easily spun off the road at 70mph and fell 200-500ft off the hill side. NEVER AGAIN! I keep 4 stems in my garage so if they are ever needed I have spares!! (if Schwab's dose not have them in)
Name:	tire valve stem.jpg
WALNUT (anti-ACORN) member#23
Trip is offline
post #8 of 8 (permalink) Old 07-07-2010, 08:41 PM
Trip's Avatar
If you are paying $400 in commuter car tires or $2000 in truck tires what is 40 bucks to keep air in them correctly
Trip is offline
valve stems O2ShootTheJ General Parts and Accessories 6 10-17-2009 01:24 AM
Are there any differences between the 08s an 09s Diesel Guy 2008-2010 6.4L Power Stroke 7 06-10-2009 02:20 PM
04-05 differences Skyhigh4by 2003-2007 6.0L Power Stroke 3 02-02-2008 12:39 AM
6.0 differences ford572 2003-2007 6.0L Power Stroke 5 02-08-2007 08:40 PM
metal valve stems??? BK Meyers 1994-2003 7.3L Power Stroke 0 04-18-2006 09:24 PM
