Sulastic rubber shackles?? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by bootcamp, this thread has received 0 replies and been viewed 1075 times.
post #1 of 1 (permalink) Old 07-06-2010, 12:06 AM Thread Starter
bootcamp's Avatar
Has anybody use these shackles, ran across them the other night. This is another company that makes the 2 piece shackle for the rear leaf springs to take some of the buck board affect out of our trucks.
Thanks Paul
https://www.sulastic.com/Default.aspx
USMC 87-90 MOTOR-T
Build Date 01/05 05 F250 4x4 swb cc lariat
SCT XCAL3 Tune by DFuser,fluid damper,MBRP exhaust-no kitty, crossover fuel line, Coolant filter, CFM Intake elbow, Pro Comp 6" stage 2 lift and traction bars,ccv reroute, Gauges-trans,pyro,fuel,bbreg mod, B&W goose neck and companion hitch, firestone airbags, Earls anplumbing-6 hose and fittings to upgrade fuel lines,T/P stage I fuel line kit,Welded up pipe and welded egr cooler install, 4.10 yukon gears, ceramic coated manifolds install with new head gaskets and ARP's, PML trans pan, AEM brute air filter, AirDogII 165 sucking it straight off the bottom of the tank with Hellmans sump and Strictly Diesel RR kit
2010 Honda VFR1200 for when I really want to go FAST My newest collection to the armada, 2004 VW R32 and its all wheel drive
SINGLES CLUB MEMBER #259
bootcamp is offline
Stock shackles 6.0turbodiesel03 Ford Parts wanted 2 03-19-2010 02:31 AM
Cutting rear shackles? toylet 2008-2010 Body & Suspension 9 06-20-2009 06:13 PM
2in Drop Shackles imported_Stroker01 1994-2003 7.3L Power Stroke 1 01-19-2008 07:17 PM
01 Leveling Shackles fire1998 1994-2003 7.3L Power Stroke 21 12-28-2007 02:31 PM
Shackles and Hanger 03RescueDiesel Whats Been Sold 4 08-05-2007 03:45 PM
