Adjustable Track Bar for 05/06 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Squatch, this thread has received 7 replies and been viewed 1398 times.
post #1 of 8 (permalink) Old 02-14-2006, 01:37 PM Thread Starter
Squatch's Avatar
Does any one make one yet? I have a leveling kit and want to center the axle back up
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
post #2 of 8 (permalink) Old 02-15-2006, 03:05 AM
theyre kinda steep, but DR makes one for $275
05 f350 crew cab long bed, 10.5" rize, deaver rears, bilstein 5150s front and back, 38x15.50x18 **** cepek mud countrys, 18x9.5 pro comp 1023s clearcoated, 4.56s, pml diff covers, rize ladder bars, rize dual stabilzer with bilsteins, adj. trac bar, amp reasearch steps, doug tuned sct, airaid with zoodad, 5" straight pipe, fluidampr, welded egr, shimmed regulator, isspros, viair 480c with nathan p3, husky mats, marathon seat covers, uws toolbox, uws 100 gallon transfer tank w/15gpm pump, uws dog box
01 f150 supercrew, 33" mud grapplers, stock, for sale $13,000
05 brute force 750, snorkeled, lifted, 29.5x12 outlaws front and back, black type 7s, intake, hmf pipe, moose, asr tie rods
06 raptor 700se, 734cc, 10.75:1, cammed, intake, ported/polished, yoshi pipe w/ fmf header, power commander, 15t front, yfz shocks, 20" holeshots, soon to be 770 stroker...
mikeym is offline
post #3 of 8 (permalink) Old 02-15-2006, 03:23 AM
BogginF350's Avatar
Dont like the front end pulled wayyy over to the drivers side look? Btw, Im still working on my lil 7.3 project..:Thumbup:
Josh Davis
6.0L Ford
6.4L Ford
WWW.RIVERCITYDIESEL.COM
(309) 699-2488
BogginF350 is offline
post #4 of 8 (permalink) Old 02-15-2006, 10:00 PM Thread Starter
Squatch's Avatar
No I want to get it centered back up. It's really noticable since I put new tires and wheels on it.
I think I am going to make my own shouldn't be very difficult
I am still working on getting you a cooler
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
post #5 of 8 (permalink) Old 02-16-2006, 10:34 AM
Squatch Just wondering what size wheels and tires you have on your truck, what is your back spacing and is there any rubbing?:Thumbup:
birddog55 is offline
post #6 of 8 (permalink) Old 02-20-2006, 12:41 AM Thread Starter
Squatch's Avatar
Sorry it took so long to reply. I was out of town for a while. I have 35x12.50x18 BFG Mud Terrains on Eagle Alloy 186 18x9 with a 5in. backspace. With a 2.5in leveling kit I had to pull back the inner fenderwell and modify my mudflaps (ford molded flaps). Under normal driving on the road they do not rub but I think they would rub if I went through a ditch or something off camber while turning. A wheel with a 6in. backspacing would not rub. I was just looking for a little wider stance a wheel with some depth to it not just a flat surface.
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
post #7 of 8 (permalink) Old 02-20-2006, 02:16 PM
BogginF350's Avatar
I was going to buy a tie rod sleeve off like a 99 to 04 superduty or drag link? I cant remember, and have it turned down and threaded to match the sleeve threads.
Josh Davis
6.0L Ford
6.4L Ford
(309) 699-2488
post #8 of 8 (permalink) Old 02-20-2006, 03:40 PM
whats the part number for this?:thanks: never mind i found it dr 6-4030
looks like i gotta spend more money.
junior is offline
