Will this thing work on the 7.3? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by gregrob, this thread has received 9 replies and been viewed 686 times.
post #1 of 10 (permalink) Old 02-14-2006, 06:24 PM Thread Starter
I wish there were more details, look cool.
http://cgi.ebay.com/ebaymotors/GARRE...QQcmdZViewItem
:barf:
gregrob is offline
post #2 of 10 (permalink) Old 02-14-2006, 07:07 PM
CSIPSD's Avatar
I dont see how that would would mount, it seems backwards... and did I say BIG
CSIPSD is offline
post #3 of 10 (permalink) Old 02-15-2006, 02:33 AM
its vgt. youll need a pretty major computer modification to get it working properly. i dont know much about aftermarket 7.3 stuff, but that is about the same size as the aftermarket 6.0 turbos that are about to hit the market. we have stock gt37s, and i think the aftermarket turbos coming out are similar to the gt40s bigger brother, the gt42. sooooo, it should fit...
05 f350 crew cab long bed, 10.5" rize, deaver rears, bilstein 5150s front and back, 38x15.50x18 **** cepek mud countrys, 18x9.5 pro comp 1023s clearcoated, 4.56s, pml diff covers, rize ladder bars, rize dual stabilzer with bilsteins, adj. trac bar, amp reasearch steps, doug tuned sct, airaid with zoodad, 5" straight pipe, fluidampr, welded egr, shimmed regulator, isspros, viair 480c with nathan p3, husky mats, marathon seat covers, uws toolbox, uws 100 gallon transfer tank w/15gpm pump, uws dog box
01 f150 supercrew, 33" mud grapplers, stock, for sale $13,000
05 brute force 750, snorkeled, lifted, 29.5x12 outlaws front and back, black type 7s, intake, hmf pipe, moose, asr tie rods
06 raptor 700se, 734cc, 10.75:1, cammed, intake, ported/polished, yoshi pipe w/ fmf header, power commander, 15t front, yfz shocks, 20" holeshots, soon to be 770 stroker...
mikeym is offline
post #4 of 10 (permalink) Old 02-15-2006, 03:20 AM
CSIPSD's Avatar
How? The intake and exhaust are backwards. Just asking, I just dont see it...
CSIPSD is offline
post #5 of 10 (permalink) Old 02-15-2006, 11:54 AM
BJS
says it comes w/ a controler solenoid but not sure what kind of inputs are required to make it run. Once you figure that part out the physical mounting could be dealt with.
the exhaust inlet seems to be an odd one designed to bolt directly to a manifold which you'd need to find a different housing that would allow a more conventional exhaust input or you'd be moving the turbo rather far forward to allow for the downpipe to exit with any clearance from your firewall.
To deal with the "backward" design you could mount the turbo such that it sat in the valley with the axis of the turbine shafts running parallel to the crankshaft. which would allow for the use of the existing exhaust inlet. with some modification of the stock up pipes Then your outlet from the compressor side would need to have a tight turn to direct the air foward, you'd reverse the direction the air flows through the intercooler, and depending on how you routed the compressor output hose would depend on what you did for the air intake which may need to be relocated to the passenger's side fendewell.
BJS is offline
post #6 of 10 (permalink) Old 02-16-2006, 12:02 AM
no way it will work
BIGRPOWR is offline
post #7 of 10 (permalink) Old 02-16-2006, 12:04 AM
CSIPSD's Avatar
Originally Posted by BIGRWHP
no way it will work
2: But nice first post...:
CSIPSD is offline
post #8 of 10 (permalink) Old 02-16-2006, 12:11 AM
you like that don't you. there's only a few turbo's that work on our trucks as far as i know, stock,h2e, bb, qssb, ballbuster,gt42 and that's it right. and then maybe ultra custom stuff maybe?
BIGRPOWR is offline
post #9 of 10 (permalink) Old 02-16-2006, 12:16 AM
CSIPSD's Avatar
That one would take a little work...
CSIPSD is offline
post #10 of 10 (permalink) Old 02-16-2006, 05:52 AM
It could work. How much time to you have to devote to it? Also how much money?
PSDPlayer is offline
