2005-5r110 leak - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Bcarriveau, this thread has received 2 replies and been viewed 2036 times.
post #1 of 3 (permalink) Old 09-14-2010, 03:02 AM Thread Starter
********* and Mafia #90
Bcarriveau's Avatar
2005-5r110 leak
just as it says, its starting to leak pretty back from between the bellhosing, actually drips from a starter bolt...
anyone run into this? simple front seal? its been dripping over time and now dripping pretty good. its clocked at 110k and has never been serviced. does not slip
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
post #2 of 3 (permalink) Old 09-14-2010, 03:55 AM
harry6.0's Avatar
Bill, its definitely tranny fluid, or is it possibly motor oil? Mine has dripped motor oil from the bell housing since new. Warranty tried a rear main way back, but mine is the bed plate. Its so minor, that it dosen't even drip on the ground in the garage, not worth tearing into in my opinion. But if yours is the transm, then I could only think its the torque converter seal or the front pump seal. Harry
harry6.0 is offline
post #3 of 3 (permalink) Old 09-14-2010, 04:38 AM Thread Starter
Bcarriveau's Avatar
100% trans fluid..
Da Rules..Here
Dear Tequila:
The TDG TOTQ
2005 F350 6.0 oil leak scarr133 2003-2007 6.0L Power Stroke 7 12-30-2009 11:21 PM
6.0l 5r110 Torque Converter and 6.4l 5r110 suncoast converter Blk350on20s Whats Been Sold 5 02-12-2009 11:12 PM
2005 Excursion PS vs. 2005 F-series PS deb0650 2003-2007 6.0L Power Stroke 3 04-07-2007 07:23 PM
Used 5r110 Morpheus cycles Whats Been Sold 1 03-30-2007 05:11 PM
Oil Leak Or Boost Pressure Leak At Hot Side Charge Air Cooler (cac) Duct PSDPlayer 2003-2007 6.0L Power Stroke 2 01-12-2007 05:17 AM
