92 F350 Power steering help please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by sxpck628, this thread has received 1 replies and been viewed 950 times.
post #1 of 2 (permalink) Old 11-09-2010, 03:14 PM Thread Starter
92 F350 Crew Cab with 7.5 (460) 4x4. Been having power steering trouble, the funny thing is that it has power assist turning one direction but not the other, I disconnected the hoses from the pump and blew about 30lbs of air back through the return line while truning the wheel at the same time. I think there may be a valve plugged in the steering box. Is this something that I can fix/rebuild or should I just get it replaced? Are there any other trouble shooting ideas out there?
Thank you
sxpck628 is offline
post #2 of 2 (permalink) Old 11-12-2010, 06:53 AM
4play's Avatar
If its good one way but not the other, and you know for sure nothing is binding on the steering linkage (unlikely) its got to be in the gear box.
The steering gears are not overly complicated to disassemble but I would recommend having a manual to refer too. Im also not sure on the availability of parts that might be needed. If you find a problem and get it fixed, how sure are you going to be that the rest of the stuff is going to be ok? You might just see what you can get a rebuilt on for before you go too far. Good luck.
4play is offline
Power Steering Crown Vic Guy 2008-2010 6.4L Power Stroke 5 12-19-2009 09:15 PM
power steering cwood22 2003-2007 6.0L Power Stroke 13 04-27-2009 03:50 AM
No power steering or power brakes bigdaddy1 5.9L Cummins (1998.5-2002) 7 01-24-2009 05:53 PM
power steering mxjeepin 1994-2003 7.3L Power Stroke 4 04-19-2008 10:25 PM
1992 f350 steering ? stroker1 General Ford Truck and Excursion 2 01-07-2008 02:14 PM
