Easy question for lift guru's part 2 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by nummit, this thread has received 2 replies and been viewed 472 times.
post #1 of 3 (permalink) Old 02-20-2006, 12:05 PM Thread Starter
When I go under the front of the truck, there are two adjustment collars.One goes from the pitman arm to the pass side tire,the other ties the two front wheels together,which one do I adjust top or bottom?
nummit is offline
post #2 of 3 (permalink) Old 02-20-2006, 04:49 PM
You adjust the one on the drag link (the upper one that connects to the pitman arm).
The lower one is to adjust your tie rod....will mess up your alignment (assuming it's aligned right now)....
DCSpecial is offline
post #3 of 3 (permalink) Old 02-21-2006, 12:50 AM
its a bar with a collar in the middle, with 2 bolts on the ends. loosen the 2 bolts on the collar, and twist it until youre straightened out...
05 f350 crew cab long bed, 10.5" rize, deaver rears, bilstein 5150s front and back, 38x15.50x18 **** cepek mud countrys, 18x9.5 pro comp 1023s clearcoated, 4.56s, pml diff covers, rize ladder bars, rize dual stabilzer with bilsteins, adj. trac bar, amp reasearch steps, doug tuned sct, airaid with zoodad, 5" straight pipe, fluidampr, welded egr, shimmed regulator, isspros, viair 480c with nathan p3, husky mats, marathon seat covers, uws toolbox, uws 100 gallon transfer tank w/15gpm pump, uws dog box
01 f150 supercrew, 33" mud grapplers, stock, for sale $13,000
05 brute force 750, snorkeled, lifted, 29.5x12 outlaws front and back, black type 7s, intake, hmf pipe, moose, asr tie rods
06 raptor 700se, 734cc, 10.75:1, cammed, intake, ported/polished, yoshi pipe w/ fmf header, power commander, 15t front, yfz shocks, 20" holeshots, soon to be 770 stroker...
mikeym is offline
