Need information on the rear ends under 2001 E250ís - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Lonesome7.3, this thread has received 9 replies and been viewed 3057 times.
post #1 of 10 (permalink) Old 12-23-2010, 01:24 AM Thread Starter
I was looking at the rear end under an E250 in a salvage yard today. The date code is 11/00 so I am assuming that means 2001. The axle code on the data plate said 35. I thought it was going to be Sterling. Nope, when I looked underneath I figured it was a Dana 60. It had Dana stamped clear as day on the cover. But it looks different. It does not look like the 60ís I have and have had. I could not find 60 stamped anywhere on it. So, what is it? Also, what lug pattern do they have? I did not have a tape measure on me so I could not verify if it is the same lug pattern on the truck I want to install it under. I was looking at it for a 96 F250 with the old standard eight lug pattern. Oh yeah, this rear end did not have the hubs sticking out like 60ís and Sterlingís. I have seen that on the smaller 14 Bolt but I have not seen it on a Ford. Can anyone bring me up to speed on what this van has?
post #2 of 10 (permalink) Old 12-23-2010, 01:39 AM Thread Starter
Sorry, I should have been more specific. I meant the rear end was a semi float eight lug. It also had disc brakes if that helps.
post #3 of 10 (permalink) Old 12-25-2010, 03:29 PM
Should have the 8x170 bolt pattern the vans switched patterns the same time the trucks did... it may be a regular dana 60?... I thought the E150s had the small axles and the E250's & E350s had the bigger axles?
2000 Excursion XLT 4x4, 12V P Pump Cummins, 0-ringed head, AE G56 6 spd, southbend FE clutch, guages, lazer dv, 370's, Black Vinyl floor, 285 Nitto Dura Grapplers, 4" remote BD Exhaust Brake, 4" exhaust, Working on Twin turbos HX50 9cm &BHT3E 20cm with tial external wastegate, http://www.turbodieselregister.com/f...sion-redo.html
1992 dodge w350 cummins, SRW, 5spd Getrag, 3.07 gears, guages, custom 8' dumping flat bed
1996 VW Passat TDI Wagon, guages, Chip, Big injectors Rebuilt KKK24 Turbo, 2.5 " stainless techtonics exhaust, 5 bolt GLX brakes, bilsteins HD suspension, Shine rear swaybar, frost heater, heated black leather interior.
therabbittree is offline
post #4 of 10 (permalink) Old 12-25-2010, 05:06 PM Thread Starter
The kug pattern is what realy concerns me. I have heard the vans kept the old pattern for a while. I wish I had my tape measure when I went out there.
post #5 of 10 (permalink) Old 12-26-2010, 05:15 AM
4play's Avatar
Sounds like your familiar with the Sterling and Dana 60. The Sterling was semi-float 9.75" The 60 was either semi or full float. Its probably a 70 that you saw, Dana 80's were in the duallys.
There were 2 D70's ( 70-2U & 70TR ) TR is the heavy duty version. The 70-2U is nearly identical to the D60. The 70TR has a big cast rib that goes from axle tube to axle tube across the top of the pumpkin, it also has 5-bolt flanges for the backing plates vs 4.
As far as I know the bolt pattern for the E series never changed and its still 8x6.5 ( 8x165mm ) Maybe it changed in the last couple years but back then.
Axle code: 35 — 4.09 ratio, non-limited slip (E-250, S-250, E-350, S-350)
Code 35 — 4.09 ratio, non-limited slip (E-250, S-250, E-350, S-350)
4play is offline
post #6 of 10 (permalink) Old 12-26-2010, 07:56 PM Thread Starter
Where did you locate that axle code?
post #7 of 10 (permalink) Old 12-27-2010, 09:14 AM
4play's Avatar
Straight out of a 01 E series service manual.
4play is offline
post #8 of 10 (permalink) Old 12-27-2010, 05:22 PM Thread Starter
Cool, thanks. Now I have to decide if I want to go with a semi float rear.
post #9 of 10 (permalink) Old 12-27-2010, 10:17 PM
4play's Avatar
I just re-read your first post, I missed the part about the hubs, looks like its the semi-float 60. The complete axle is identical to all other 60's other than the hubs/axle shafts. The cover on the Sterling will look the same as the bigger ones but it is semi-float too and with smaller guts inside.
4play is offline
post #10 of 10 (permalink) Old 12-27-2010, 11:15 PM Thread Starter
Being since it will be going in a 3/4 gasser, I think a semi float 60 would be fine.
best rear ends for pullin? scarty Medium and Heavy Duty 15 08-20-2010 04:35 AM
2001 2500 rear end robot General Dodge Discussion 0 06-29-2010 05:50 AM
Rear Ends? NickTF 5.9L Cummins 12 Valve (1994-1998.5) 3 02-27-2007 02:23 PM
410 rear ends stumppuller 6.5L Diesel Engine 0 10-31-2006 12:42 AM
GM TechLine 2001/2002 Service Information hoot Whats Been Sold 2 03-05-2006 03:17 AM
