'04 F-250 front springs - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Diesel Duo, this thread has received 5 replies and been viewed 3003 times.
post #1 of 6 (permalink) Old 03-10-2011, 05:01 AM Thread Starter
Diesel Duo's Avatar
Hello,
My factory leaf springs are sagging, so I am in the market for replacements.
First, what exactly is the snow plow prep package for that year?
Second, are F-250 and 350 springs the same lenght eye to eye? Can they be interchanged?
Third, what in your experiences are the best replacements; I am only looking for a leaveling shock no large lifts. Please, keep in mind I will be hanging a plow over the front so soft shocks are not an option.
Thank you for all your opinions,
Ryan
No brand loyalty, just a love of diesels!!
1994 Ram 2500 CTD K&N intake, MBRP exhaust, full Goerend tranny, #100 Fuel plate, 60# valve springs, 4k GSK, Thuren steering stabilizer, Thuren Track Bar, +2.5" progressive rate coil springs, Bilstein 5100's, BD Diesel SBS, chassis mods, 315/75R16 Goodyear Wrangler Duratrac, Isspro tri-pod EGT, fuel, and boost, Eclipse CD, 8' Boss snowplow
Fuel Heater Deleted! KORE dual Heim Joint end links waiting to go in
2004 F-250 Powerstroke aFe stage II, Hypertech PTM, Recon mirror markers, Firestone airbags w/ compressor, Rancho 9000's on all four w/ myride, 20" Pacer on 33/12.5 Nitto Mud Grapplers, Eclipse CD, 8' Boss snowplow
Blizzard IceChaser 1.5 cubic yd. poly salt and sand spreader!
Diesel Duo is offline
post #2 of 6 (permalink) Old 03-10-2011, 11:22 PM
diesel weenie
Originally Posted by Diesel Duo View Post
Hello,
Ryan
The snow plow package was a set of springs and a bigger alternator.
Yes, they are the same length, the only difference is the spring rate. there were 5 rates available (that I remember) depending on your truck.
Levelling kit only, I'd go with a Icon spring drop kit. I am running the 4.5 inch spring drop kit with snow plow springs. it's higher than a levelling kit, but not too much.
monkeyboy is offline
The Following User Says Thank You to monkeyboy For this addition to TDG:
Diesel Duo (03-10-2011)
post #3 of 6 (permalink) Old 03-11-2011, 12:29 AM Thread Starter
Diesel Duo's Avatar
Thank you.
I am looking at the 4" spring system.
I do not see how I would run this system along with the airbags in rear.
Also, what length of shocks are needed with this system? What do you run?
Thanks,
Ryan
post #4 of 6 (permalink) Old 03-13-2011, 06:11 AM
Needs more mod money !
njneer1's Avatar
Get leveling springs from rough country.......will lift it 2.5" or so in the front and handle the plow fine.....http://www.roughcountry.com/ford_4wd..._leveling.html
2000 Limited, 118K, 7.3L, 285 Cooper ATR's, super chips 1705 on tow/performance, Bilsteins, EGT/Boost/ Trans temp
njneer1 is offline
The Following User Says Thank You to njneer1 For this addition to TDG:
Diesel Duo (03-13-2011)
post #5 of 6 (permalink) Old 03-13-2011, 06:52 AM Thread Starter
Diesel Duo's Avatar
I know most of the time; if something looks too good to be true it probably is.
I see the cost savings.
I just don't know if the Rough Country is a progressive leaf pack? As i am not looking for a loss of ride quality.
Does anyone have experience with any of these systems / or similar?
Thanks,
Ryan
post #6 of 6 (permalink) Old 03-13-2011, 01:49 PM
njneer1's Avatar
That is what I am using on my Excursion.....it did stiffen the Ex quite a bit......but Excursions are very sloppy and soft. Mine was down on the bump stops......
Ex's are 2" lower than trucks so I got a 4" lift out of it ....added a 2" add a leaf with the 2.5" front F250 leveling springs and it was sitting level.....anything you add or change will stiffen your ride .....your springs are sagging and weak.....but that makes them ride great......why don't you just add the front airbag kit ??.....seems like that would solve your problems if you don't want to lift it and sacrifice ride....
njneer1 is offline
Front springs chrisnjane1199 Dodge Suspension 1 11-30-2009 01:44 PM
F/S xcode front springs and pro comp rear 4.5" lift springs 6slow Whats Been Sold 4 04-26-2009 04:37 AM
99 to 04 F-250 4x4 front springs racehauler Whats Been Sold 2 01-31-2008 05:39 PM
05 front springs birddog55 2003-2007 6.0L Power Stroke 1 08-13-2006 06:51 PM
f-250 front springs.... blowing smoke 1994-2003 7.3L Power Stroke 2 05-21-2006 08:48 PM
