help truck drives like **** - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Daveboys, this thread has received 8 replies and been viewed 1772 times.
post #1 of 9 (permalink) Old 05-24-2011, 07:25 PM Thread Starter
My truck seems to dart when you hit a bump or when you are moveing left of right but staying in the same lane. What I tring to say is that if I want to move the truck 12 inches to the right and stay in my same lane, if I turn the wheels that way the truck slow starts to go that way and then takes off and you have to jerk it back. It didn't drive like this 10 years ago...it also didn't drive like that last year.
So far I have replace the sway bar links and bushings, shocks, ball joints, drag link, gear box and power steerng pump. Every thing seem to help a little but nothing fixes it. The axle joints were ok as were the tie rod ends. The truck has also been alligned twice and has new tires on it.
right now the allignment is
front
camber .2 .3
caster 3.1 2.8
Toe .03 .01
total toe .04
steer ahead .01
rear
camber -.03 .0
toe .17 -.28
total toe -.11
thrust angle .22
Does anyone have any idea what to try? The second allignment shop thought the gear box needed adjusted. It was a rebuilt read head box, but they didn't mess with it.
thanks
Daveboys is offline
post #2 of 9 (permalink) Old 05-26-2011, 12:24 PM
harry6.0's Avatar
Too much freeplay in the steering gearbox could cause your issue, but also if something in the rear suspension is loose could cause your symptom. Check all the axle u-bolts and leaf spring mounts. Is your truck 4wd or 2wd? If its 4wd, did you replace both upper and lower ball joints? I know on my truck, it would wander with worn front ball joints. Your rear thrust angle is 22 minutes, which is only about 1/3 of a degree, ideally 0 thrust is best, but all in all your alignment specs are not too bad.
Harry
harry6.0 is offline
post #3 of 9 (permalink) Old 05-26-2011, 08:39 PM Thread Starter
the truck is a 4x4. the upper and lower ball joint are new moog. The pass the tsb torque test. The gearbox is a 2 week old rebuilt redhead.
Daveboys is offline
post #4 of 9 (permalink) Old 05-31-2011, 09:06 PM
coreystroke02
coreystroke02's Avatar
My truck does the same. The cause of mine is leaf spring bushings are shot. I replaced my sway bar bushings with new poly ones, but haven't tackled the leaf springs.
2002 F-250 Crew Cab 4x4, DP-Tuner 60 tow, 80 eco, 120 race, and 140 smoke, Banks wastegate, Banks Transcommand(bypassed), 4" SS exhaust, AFE stage 2 intake, Superlift 6" lift, 37" Nitto Terra Grapplers, 18" Motto wheels, EGT and Boost gauges.
coreystroke02 is offline
post #5 of 9 (permalink) Old 06-02-2011, 05:42 PM
I be Architect'n
What about the Unit bearing hubs? Any problems going into/out of 4wd?
2K3 EXCURSION 7.3L 4x4 EDDIE BAUER 107K miles as of 06-13-07
AFE Stage II / 4" MBRP exhaust / DP-Tuner F5 (Stock, 60hp Tow, 80hp Econo, 120hp race & High Idle) / Quadzilla Commander/ATS Housing
Running homebrewed BioDiesel and custom SVO kit for 70k miles.:Thumbup:
Misc. Mods: ZooDad/By-Pass Oil Filter/203* T-Stat/Coolant Filter/HPX/CCV Reroute/Tranny Filter/Foil Delete/Stereo Stuff/ITP Reg Return/Non-EBPV Pedistal and Exhaust Housing/Adjustable Waste Gate Controller/
"If you love your motorcycle, set it free. If it comes back to you it was probably a high-side."
I'LL TRY TO KEEP UP, BUT THE EXCURSION IS A BIG GIRL AND BIG GIRLS DON'T LIKE TO MOVE FAST.
6_Myles is offline
post #6 of 9 (permalink) Old 09-13-2011, 08:26 PM Thread Starter
The front or rear leaf spring bushings? Have you changed them yet did it help?
Daveboys is offline
post #7 of 9 (permalink) Old 09-13-2011, 08:27 PM Thread Starter
The unit bearing are fairly new. Some time I have noticed that the hubs don't unlock as quick as they should. Could that cause the problem.
Daveboys is offline
post #8 of 9 (permalink) Old 09-14-2011, 05:55 PM
Stuck in Commiefornia...
IdahoF350's Avatar
I'd be re-checking/replacing Idler arm, steering tie rod ends, and as stated, the leaf spring bushings, also check the track bar bushing. I've always found a sudden change in steering to come from a worn component somewhere in the system. There's not much else it can be.
2000 Excursion XLT 4x4
IdahoF350 is offline
post #9 of 9 (permalink) Old 09-15-2011, 10:32 PM Thread Starter
Could one weak leaf spring inthe front cause this problem?
Daveboys is offline
starts but drives like crap peanut 1994-2003 7.3L Power Stroke 4 07-03-2009 01:37 PM
Small shaft drives imported_LovinPSDs The Parking Lot 6 05-10-2007 04:32 AM
McRat drives the PPE shop truck to 12.16 on #2 Kat Drag Racing 5 07-20-2006 07:04 PM
Durmax drives mouth out ran his truck adamsdieselperformance Road Kill, Bench Racing 9 03-23-2006 12:57 AM
