2007 F-250 4X4 20 inch Wheels - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by screwball, this thread has received 2 replies and been viewed 3243 times.
post #1 of 3 (permalink) Old 12-03-2011, 11:51 PM Thread Starter
2_007 F-250 FX4
What is the maximum size tire that will fit without a lift kit?
screwball is offline
post #2 of 3 (permalink) Old 12-04-2011, 12:52 AM
dzljon's Avatar
I was thinking the same thing. but even with the next size bigger i think you will have to put a leveling spacer in.
99.5 F250, VGT 5.9 CR cummins
dzljon is offline
post #3 of 3 (permalink) Old 12-22-2011, 01:48 AM
Stuck in Commiefornia...
IdahoF350's Avatar
'05+ trucks with factory 20" wheels can go 35" tall no sweat, the OE tire is like 34.4". Personally I would find the tire style you like and run the OE size, a 35" tire will cost a lot more and won't gain enough to justify the cost. Anything over 35x12.5-20 will rub the radius arm pretty good, you really need an aftermarket when with the correct offset/back spacing to run a 36" or taller tire. You'll also need to raise the nose a bit if you go over 35s, like 4-6" for 35s-37s, 6-8" for 36s-38s. And of course it all depends on what you plan to use it for.
2000 Excursion XLT 4x4
IdahoF350 is offline
1999-2007 FABTECH 8 INCH REAR SPRINGS STROKERBO Ford Parts 3 04-19-2010 07:06 AM
2005-2007 8 inch lift trade for stock parts. fordboyyfm Whats Been Sold 2 05-05-2009 01:43 AM
Anyone selling 08 20 inch wheels???? MRBOHN23 2008-2010 6.4L Engine Tuner Forum 12 02-08-2008 03:52 AM
20 inch wheels chosen1 Whats Been Sold 4 05-03-2007 08:53 PM
2-4 inch lift on 2007 dually fordt General GM Truck Forum 10 03-26-2007 01:04 AM
