2008-2010 Intermittent Heater Temp control - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by makuloco2000, this thread has received 0 replies and been viewed 614 times.
post #1 of 1 (permalink) Old 12-02-2013, 04:42 AM Thread Starter
Heat not working right? You put it on cold and it blows hot or vice versa? Your blend door actuator is likely at fault. So I figured this was common enough on the 2008-10 Superduties to make a video of the temp blend door actuator replacement. It involves pulling some pieces of the dash that many may not be comfortable with, if you follow my video I will walk you through it. Hope this helps!
https://www.youtube.com/watch?v=dYPOtin3JUk
Check out all my Ford Tech Repair Videos @
http://www.youtube.com/user/FordTechMakuloco
Please Subscribe. Always something new and interesting!
makuloco2000 is offline
A/C Heater Control Valve tperk100 2003-2007 6.0L Power Stroke 9 01-10-2011 12:10 AM
2010 block heater firejump 2008-2010 6.4L Power Stroke 1 12-28-2010 10:54 PM
Heater Control stmline General Ford Truck and Excursion 4 11-23-2007 02:57 AM
Heater control went out Pittsburgh-05HD General Ford Truck and Excursion 2 02-17-2007 02:38 PM
Heater Control wastedwagesracing 2003-2007 6.0L Power Stroke 5 11-23-2005 12:36 PM
