zoodad - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by n2diesel, this thread has received 5 replies and been viewed 721 times.
post #1 of 6 (permalink) Old 10-29-2006, 03:28 PM Thread Starter
n2diesel's Avatar
zoodad
what is a zoodad and how do you do it?
2000 FORD F250 2WD 7.3 6spd,
BULLYDOG MONITOR,BULLYDOG 6 POSITION CHIP,BULLYDOG 4" EXHAUST,AFE STAGE 2 COLD AIR INTAKE, Garrett gtp38r turbo, SOUTHBEND CLUTCH AND FLYWHEEL,BILSTEIN SHOCKS ,7 GALLON AIR TANK,SEALED VIAIR AIRCOMPRESSOR,ANVIL AIR HORNS,(2) 10 JL AUDIO SUBS, (1) MEMPHIS AMP AND (1) SONY XPLOD AMP, Truck bed has been LINEX'D in 2010, Fire and Ice brake light,
n2diesel is offline
post #2 of 6 (permalink) Old 10-29-2006, 03:44 PM
https://www.thedieselgarage.com/forum...ead.php?t=1783
FIREBALL is offline
post #3 of 6 (permalink) Old 10-29-2006, 03:48 PM
fordt
Cut out a big section of the radiator support header to allow a free flow into the air intake. Look at the intake on your truck. It stops right behind the header panel. I just cut mine out completely in stead of drilling holes, no problems out of doing this so far. :Thumbup:
post #4 of 6 (permalink) Old 10-29-2006, 05:51 PM
I did the same, used a small air saw at work...cut through it like butter. I got my info off the WIKI site.
2001 - F-250 7.3 4x4 - Auto 190K miles, 5" exhuast, F350 rear leafs, 07 Face lift
2003 -- Excursion LTD 7.3 Powerstroke 4x4 -Maintain DIY air fiilter, CHP Cold Air Inake,10K mod, XM Radio-Gone for ever
mille-ryan is offline
post #5 of 6 (permalink) Old 10-29-2006, 06:39 PM
take an air saw and hack it all out. just drill a new hole for your temp sensor...
05 f350 crew cab long bed, 10.5" rize, deaver rears, bilstein 5150s front and back, 38x15.50x18 **** cepek mud countrys, 18x9.5 pro comp 1023s clearcoated, 4.56s, pml diff covers, rize ladder bars, rize dual stabilzer with bilsteins, adj. trac bar, amp reasearch steps, doug tuned sct, airaid with zoodad, 5" straight pipe, fluidampr, welded egr, shimmed regulator, isspros, viair 480c with nathan p3, husky mats, marathon seat covers, uws toolbox, uws 100 gallon transfer tank w/15gpm pump, uws dog box
01 f150 supercrew, 33" mud grapplers, stock, for sale $13,000
05 brute force 750, snorkeled, lifted, 29.5x12 outlaws front and back, black type 7s, intake, hmf pipe, moose, asr tie rods
06 raptor 700se, 734cc, 10.75:1, cammed, intake, ported/polished, yoshi pipe w/ fmf header, power commander, 15t front, yfz shocks, 20" holeshots, soon to be 770 stroker...
mikeym is offline
post #6 of 6 (permalink) Old 10-29-2006, 10:07 PM
Old Geezer-TDG Mafia #19
LargeCar's Avatar
Images: 9
Be sure to use protective stuff the core support is a composite and has glass fibers that will make you wish you had.
LargeCar :mafia
LargeCar
Mafia # 19 The Dually Club # 19
If a country does not remember and honor its fallen heroes of the past, in the future that country will not be honored or remembered.
G.R. Wemmer
A veteran is someone who, at one point in his/her life wrote a blank check made payable to 'The United States of America' for an amount of 'up to and including their life.' That is Honor, and there are way too many people in this country who no longer understand it.
LargeCar is offline
