Clunk when i step on the brakes - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by aldo_45030, this thread has received 4 replies and been viewed 392 times.
post #1 of 5 (permalink) Old 10-30-2006, 01:36 PM Thread Starter
You can feel it through the floor. Occcurs apprx 80% of the time and seems to be getting worse. Possible bjoint problems?? i have checked to see if anything was loose and found nothing obvious. i have not jacked it up and wiggled yet.
2003 F350 CC SRW 4X4, 4" banks turbo back, 4 pos dp tunes, afe2 intake, leveled, gauges
aldo_45030 is offline
post #2 of 5 (permalink) Old 10-31-2006, 02:35 AM
maybe the tie rod end or the ball joints.
ford_truck_1976 is offline
post #3 of 5 (permalink) Old 10-31-2006, 05:34 PM
does it do it when you take off again after stopping, i've seen similar things when the tranny or tcase mounts get warn or loose and it allows the tranny or tcase to shift position.
2010 F250 6.4 - Stock
SOLD 2001 F250 7.3 Platinum Edition
Garrett Ball-Bearing Turbo/AFE Stage 2/AIH Plug/Sonnax/5" Exhaust/DP-TUNER Chip
R_S_C is offline
post #4 of 5 (permalink) Old 11-01-2006, 07:04 PM
The sway bar end-link bushings are toast on my truck and they do exactly what you described.
steevil is offline
post #5 of 5 (permalink) Old 11-01-2006, 08:51 PM
It could also be a bad cab or front clip mount isolator bushing that goes between the frame and the body. I have seen those go bad on superduties and excursions over the last 5 or 6 years.
2006 F250 XLT 6.0 CC Shortbed auto with Leer cap and fire engine red. Stock everything but running a
SCT Xcal2 tuned by Innovative Diesel. :smoke
Gillagorilla is offline
