stock 06 f-350 what size tires - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by yamaman, this thread has received 4 replies and been viewed 6215 times.
post #1 of 5 (permalink) Old 11-12-2006, 03:08 PM Thread Starter
hey everyone I was wandering I have a stock 06 f-350 cc 4x4 and was wandering what size of tires i can fit without putting on a leveling kit or anything. I don't have the time right now to get one or put one on but I need new tires and don't want the factory size. i want to go alittle bigger and definately wider. So I have the stock 18" rims that i will be using for now too. What size tire would give me alittle meaner stance. I am looking at the toyo M/T's. thanks everyone
yamaman is offline
post #2 of 5 (permalink) Old 11-12-2006, 05:13 PM
member
Jarods gerbils's Avatar
I'm in the same boat as you. Toyo and Good year make the 275/70/18, same size but much more agressive treads. BFG,s are making some different sizes too but are a little pricey. Nitto Terra Grapplers make some bigger sizes but have heard some good things but a lot of bad. noisy and wear fast.Thats about all I know, so if you find anything new let me know.:Thumbup:
Also could go with a 17" rim, theres a lot more options, I'm still throwing that idea around.
2006 F-350 6.0 crew cab long bed with line x.
2" leveling in front with 315/65/18 BFG's.
Billet grill
MBRP 4" duals, AFE stage 1, Tunes from Eric @ Innovative and DJ's.
Overhead pod with Isspro guages
Jarods gerbils is offline
post #3 of 5 (permalink) Old 11-12-2006, 08:23 PM
LokiWolf's Avatar
You can go 33 stock, and with a leveling kit you can go 35 with rubbing while turning and flexing at the same time. I had the Pro-Comp AT 33's Stock, and I now have the Pro-Comp Xtreme AT 35's. That is all on the stock rims. THey are both 12.5 wide tires.
Hope that helps...
2006 F250 CC SB 4x4
4.5 Icon 4-Link, TEI Spacers, and 5 Inch rear Springs.
Farmboy Fabrication Traction Bars.
SCT XCalII tuned by GoGoDiesel, DJ's, and Spartan...
LokiWolf is offline
post #4 of 5 (permalink) Old 11-14-2006, 12:34 AM Thread Starter
ok so I am looking at the toyo M/T's and they have a size 33x12.50x18 would those look fairly good a beefy for the time being? I just don't have the time and money right now to get the leveling kit and 35's and I need tires.
What diameter is the stock 18" tires?
yamaman is offline
post #5 of 5 (permalink) Old 11-14-2006, 01:11 AM
member
I'm pretty sure they are 33". I think they would look real good, where u looking at those at?
Billet grill
