Another Lift Question! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Galaxie_406, this thread has received 14 replies and been viewed 935 times.
post #1 of 15 (permalink) Old 11-16-2006, 04:32 AM Thread Starter
I have a 04 F-350 FX4 SRW King Ranch and I am really not happy with the rear end up as far as it is (Used Truck but I think it's Stock). I look at the F-250's and they appear fairly straight and level, my rear end looks like it's about 3-4" higher in the rear. Most of my driving is commuting and not off roading, would I be better to lift the front a bit (which should give me more travel) or lower the back and could I used the lift blocks from a 250? be advised that there are factory overload springs on the truck as well and I have a Nepolean body so I would like to keep the truck as low as possible but if I can improve the ride I will sacrifice.
Galaxie_406 is offline
post #2 of 15 (permalink) Old 11-16-2006, 04:46 AM
I had the same truck and installed a 2.5" leveling kit in the front. Allowed me to clear a little larger tire and did not affect the ride at all. Made the truck look much better. If you want to lower the rear, the 250 blocks will work and should bring it down 2 inches.
NFA Fun is offline
post #3 of 15 (permalink) Old 11-16-2006, 05:07 AM Thread Starter
If I go with the F-250 blocks, any suggestions on where to get them other than paying like gold for cast iron at the dealer?
post #4 of 15 (permalink) Old 11-16-2006, 05:39 AM
I've got a set off my 250FX4. There yours for $30 plus shipping, which shouldn't be much...i'm in nor cal.
FIREBALL is offline
post #5 of 15 (permalink) Old 11-16-2006, 02:13 PM Thread Starter
Hey Fireball, give me the measurement on those blocks (estimated) and maybe we can do something. I still need to check the rear assembly regarding the overload brackets to make sure it's not part of the block.
post #6 of 15 (permalink) Old 11-16-2006, 06:33 PM
I'll double check tonight but I think they are about 2 1/4". They have the bump stop wings. I have the u-bolts too if yours are too long.
I'll post up later tonight when I get home with the exact measurement.
FIREBALL is offline
post #7 of 15 (permalink) Old 11-17-2006, 12:06 AM
They are 1 3/4" blocks with the bump stop wings. They are off my '04 CC, SB, SRW, 4x4, FX4. (geeze what a mouth full)
Let me know.
FIREBALL is offline
post #8 of 15 (permalink) Old 11-17-2006, 12:18 AM
MAFIA #8
hhrecovery's Avatar
Images: 1
Galaxie, you can just swap the blocks out. People do it all the time w/ no problems.
2003 F250 "Pulling Truck"
hhrecovery is offline
post #9 of 15 (permalink) Old 11-17-2006, 02:45 AM Thread Starter
Yep! That's what I need to do! swap blocks. While were on the page, could I just add a block to the front leafs to bring the nose up a bit or would I need a whole "Kit"?
post #10 of 15 (permalink) Old 11-17-2006, 02:53 AM
8upwitHDs's Avatar
adding blocks to the front end is a very very bad idea. If you eject a block out of the front you are going to go azz over tea kettle. I would strongly recommend you get a proper leveling kit if that is the look you are after.
8upwitHDs is offline
