Lift For the 04 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 04-F350, this thread has received 5 replies and been viewed 449 times.
post #1 of 6 (permalink) Old 11-16-2006, 11:27 AM Thread Starter
Lift For the 04
Ive been looking around and reading all the threads on lifts. But they all seem to be on 2005 +, so.....i was looking to fit 35 to 37 under my truck (sig). Ive heard a lot of good things about donahoe racing. But dont understand the difference between the 4.5" hanger system and the 4" spring system beside the extra 0.5" of lift. Does the hanger system let you add to it if you get sick of only 4.5" ? Any help would be great.and if any one has some pics of supercab short beds lifted lets see them cause the only ones you seem to see on here are the crew cabs. Sry for long post just dont wanna spend my $$$$ on something not quality. Thanks Guys:Thumbup:
04 F350 POWER-SMOKE 6.0
SCT Tuned by Innovative, Gauges- Ultralights, Zoodad Mod, Harpooned, Coolant Filter, 4" banks Exhaust, LIPD Fuel System, ARP Headstuds, Fluidampr,MORE TO COME.............................:Thumbup:
Other Toys
-1986 Jeep CJ-7 Trail machine
-Built By me! (Fine Tuning Stage)
Hello my name is_______ and im a dieselholic
04-F350 is offline
post #2 of 6 (permalink) Old 11-16-2006, 11:47 AM
MAFIA #8
hhrecovery's Avatar
Images: 1
I have a fabtech hanger lift and am very pleased w/ it. It is very high quality, and you will be able to fit 35s on your truck w/ it.
2003 F250 "Pulling Truck"
hhrecovery is offline
post #3 of 6 (permalink) Old 11-16-2006, 04:03 PM
I also run the Fabtech hanger on my truck. In my opinion all the hangers are the same. The spring is where it is at. My understanding is the hanger allows you to run a lower spring wich in turn allows for a softer ride. For example I believe a 4" spring combined with a 4" hanger (total 8") rides nicer then a full 8" Spring. JMO
HydrillaHoundawg is offline
post #4 of 6 (permalink) Old 11-17-2006, 06:35 PM
Back In Bama
I would give Marty at Trucktoyz a call or shoot an email to DCSpecial. They know what they are tlaking about and could help you with the DR kits. I know that as soon as I save some more money I will be contacting them.
---04 F350 PSD Lariat FX4---
Paxamus is offline
post #5 of 6 (permalink) Old 11-17-2006, 07:05 PM
Supporting Vendor
The 4.5" hanger kit uses your stock leaf springs in the front. The 4" kit gives you new deaver leafs for the front.
The size tires you are talking about require different amounts of lift. To clear the 37's you would need 6"-7" of lift. To clear 35's you can get by w/ 4"-5". These recomendations are for nothing to extreme offroad. If you wanted the flew w/out rubbing you would need 6" for 35's or be willing to cut the fenders a little. Let me know if I can help we have lifted lots of these things.
Dave
D2 Hi-Performance
www.d2hiperformance.com
Proud to be a sponser of THE DIESEL GARAGE.COM!
(586) 709-2271
(586) 949-3234
Our rides
Dave P's Truck: 2002 CCSB 6.5" ProComp lift w/ 5100 Bilsteins, Crower Rods, Balanced rotating, coated rod and main bearings, ARP Head and Main studs, Fire Ringed, ported heads, machined and coated Mahle pistons, AFE stg II, Stealth pumps, BD's w/ 0.008 EH tips, D2HP Inconel exhaust valves, D2HP custom pushrods, Custom HX50 bolted to Hmax pedistal, Suncoast Comp trans, Detriot Electrac's front and rear, D2HP transfer case and 1 piece 4" Al driveshaft.
Dave D's Truck: 2002 ECLB Built Ford Tough Package 6" DR lift kit, Bilstein 5100's, 36x15.50R20 MTZ's on 20x10 114 Eagle's, Randy Ellis Bar w/4 8" Stainless ProComp 130W Lights, Custom tunes from DP Tuner, 05 Harley front end, D2HP transfer case and 1 piece Al driveshaft.
Becky P's ride: 2002 Limited Excursion, DVD, heated seats, TS and DP tunes, Edge Juice & Attitude, Dual exhaust, Bilstein stock replacments, AFE.
D2HP is offline
post #6 of 6 (permalink) Old 11-18-2006, 04:03 AM
The hanger/shackle kits lower the eyes of the spring further from the frame. Depending on the amount of lift and the desired ride firmness, it is one option to move the axle away from the frame. The 4.5" Donahoe Hanger Kit allows the use of stock springs (or lift springs in conjunction to achieve even greater lift). 4" - 4.5" lift allows the use of 35x13 tires when mounted on approx 10" wide rims. To use 37s, 6" lift is suggested. In order to to get my 6" lift, I added extra leafs to my stock springs to net 3", and I coupled that with the DR 3" Hangers and Shackles. I only run 35x13 on 18x9.5 rims, but I could easily fit 37s. I run 35s because I do like to venture on rougher terrain and I don't want any rub at any flex.
My gallery has some pictures.
2004 F-350, 4x4, SC, LB, 6.0PSD, 6spd
Changed a few things. More than some, less than others
Betaracer is offline
