Donahoe 4.5 inch lift shifted the front over? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by lilgsx, this thread has received 12 replies and been viewed 773 times.
post #1 of 13 (permalink) Old 11-19-2006, 05:21 PM Thread Starter
Images: 2
My lift on the truck has shifted the whole front end towards the driver side about a inch or two. My passengers side bump stop hits the spring and the brake bracket hits the swaybar link. Has anyone else had this problem. The Truck is a 2006. :shrug:
2006 PSD 4X4
lilgsx is offline
post #2 of 13 (permalink) Old 11-19-2006, 06:00 PM
MAFIA #8
hhrecovery's Avatar
Images: 1
Sounds like you need an trac bar adjustment, and if you didn't add and adj. one that should solve your problems
2003 F250 "Pulling Truck"
hhrecovery is offline
post #3 of 13 (permalink) Old 11-19-2006, 06:30 PM Thread Starter
Images: 2
I see that other guys got the 4.5" lift from DR and did not have to use Trac bar. Are they just lucky?
2006 PSD 4X4
lilgsx is offline
post #4 of 13 (permalink) Old 11-20-2006, 01:46 AM
8upwitHDs's Avatar
doesn't that kit come with an adjustable trac bar??? You should not use your stock bar with that kit. Also check to make sure that where the bar joins together is tight.
8upwitHDs is offline
post #5 of 13 (permalink) Old 11-20-2006, 02:00 AM
ya, mine came with an adjustable trac bar,
:Thumbup:
kris
2005 RED 6.0 PSD ext.cab LWB 4x4 t-409 MBRP 4", AFE Pro Guard 7 MEGA , RANCH HAND full replacement Front and Back, DR 4.5" lift kit, line-x extra, recon smoked, SCT extreme street:smoke:
pictures
2001 yellow jeep wrangler 6" skyjacker lift 2" body lift 36x14.5x15 swampers
1999 7.3 BLUE 4 door LWB PSD 4x4 SCT tune from DP
kkibbey is offline
post #6 of 13 (permalink) Old 11-20-2006, 04:21 AM
Yes, you MUST use an adjustable or droped track bar with a 4"+ kit.
FIREBALL is offline
post #7 of 13 (permalink) Old 11-20-2006, 10:29 AM Thread Starter
Images: 2
I tried to do so yesterday. But I need it on a lift.
2006 PSD 4X4
lilgsx is offline
post #8 of 13 (permalink) Old 11-20-2006, 11:51 AM
MAFIA #8
hhrecovery's Avatar
Images: 1
I don't know how you got your truck back together without haveing an adjustable trac bar or a drop bracket...
post #9 of 13 (permalink) Old 11-20-2006, 06:46 PM
LokiWolf's Avatar
Lilgsx...You don't need a lift to adjust the trac bar on the DR4.5. You can do it sitting on the ground with no problem.
I did mine no problem, cause it was off a little after the suspension settled, after about a week or so.
Who installed your lift because if the spring was hitting the bumpstop, they defiantely did not adjust it at all, and you should go back and yell at them.
After you adjust the Tracbar, you are going to need to adjust the steering to center your wheel.
I sent you a PM with my number. I can walk you through the whole process in minutes, just give me a call.
Later,
Ray
2006 F250 CC SB 4x4
4.5 Icon 4-Link, TEI Spacers, and 5 Inch rear Springs.
Farmboy Fabrication Traction Bars.
SCT XCalII tuned by GoGoDiesel, DJ's, and Spartan...
LokiWolf is offline
post #10 of 13 (permalink) Old 11-20-2006, 11:40 PM Thread Starter
Images: 2
I got it all done up today. It drives much better now. And it is dead nut center for the time being. I can not say enough about the ride compared to the stock ride. It is night and day! Thanks to all that help me get out of this bind.
2006 PSD 4X4
lilgsx is offline
