Rear Window Creaking. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by F250BlackChrome, this thread has received 2 replies and been viewed 499 times.
post #1 of 3 (permalink) Old 11-20-2006, 03:15 PM Thread Starter
F250BlackChrome's Avatar
Unhappy Rear Window Creaking.
I have a 2006 F-250 Crew Cab 4X4 PSD.
I have a creaking noise in the passenger side rear window area.
It makes the sound whenever the body flexes.
Took it to the dealer and they could hear the noise, but couldn't fix it. They tightened some body mounting bolts and that didn't help.
Anybody have this noise? What should they do to fix it?
F250BlackChrome is offline
post #2 of 3 (permalink) Old 11-21-2006, 04:07 PM
Still kickin
Flopster843's Avatar
Could it be that the window seal is just a little loose and allowing it to slide when the truck flexes rubbing against the body or glass? Just thinking out loud.
John
08 6.7 QC SB 4x4 "hand-shaker" edition, De-Badged, EGR Delete, TTT Mirrors, Auto Exhaust Brake, etc.
All details and instructions --> www.CarboniteCummins.com
Successfully blew up three 6.0s before moving up in the food chain.
Flopster843 is offline
post #3 of 3 (permalink) Old 11-21-2006, 08:08 PM
Supporting Vendor
I had this issue on my truck a while back due to the rear window seal 'itching' against the sheet metal on the cab. Took a can of silicone and inserted the straw between the cab and the window moulding and hosed it down the whole way around the window. You may need to pry the seal up a bit to insert the straw, I used a small screwdriver covered in tape. Wipe up the excess and the noise should be gone.
D2 Hi-Performance
www.d2hiperformance.com
Proud to be a sponser of THE DIESEL GARAGE.COM!
(586) 709-2271
(586) 949-3234
Our rides
Dave P's Truck: 2002 CCSB 6.5" ProComp lift w/ 5100 Bilsteins, Crower Rods, Balanced rotating, coated rod and main bearings, ARP Head and Main studs, Fire Ringed, ported heads, machined and coated Mahle pistons, AFE stg II, Stealth pumps, BD's w/ 0.008 EH tips, D2HP Inconel exhaust valves, D2HP custom pushrods, Custom HX50 bolted to Hmax pedistal, Suncoast Comp trans, Detriot Electrac's front and rear, D2HP transfer case and 1 piece 4" Al driveshaft.
Dave D's Truck: 2002 ECLB Built Ford Tough Package 6" DR lift kit, Bilstein 5100's, 36x15.50R20 MTZ's on 20x10 114 Eagle's, Randy Ellis Bar w/4 8" Stainless ProComp 130W Lights, Custom tunes from DP Tuner, 05 Harley front end, D2HP transfer case and 1 piece Al driveshaft.
Becky P's ride: 2002 Limited Excursion, DVD, heated seats, TS and DP tunes, Edge Juice & Attitude, Dual exhaust, Bilstein stock replacments, AFE.
D2HP is offline
