Fog / driving lights - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by HydrillaHoundawg, this thread has received 9 replies and been viewed 516 times.
post #1 of 10 (permalink) Old 11-22-2006, 01:43 PM Thread Starter
am looking for a set of dual purpose lights that will do fog/driving. or even driving/long range. I want to be able to drive in traffic with the lights on then hit high beam and have tem get brighter.
Criteria
6" round
crystal cear lense
white light or close to factory. I don't want any funky yellow or purple glow.
the piaa 520 are single purpose and the 580 doesn't have the crystal clear lense. Any ideas or other brands. I looked @ Hella and there site has so many lights its retarded. They need a better search feature IMO. HELP!
HydrillaHoundawg is offline
post #2 of 10 (permalink) Old 11-22-2006, 02:16 PM
Look at the piaa racing 80's. There 8" lights,, but they do what you described. They have a sharp cutoff in low beam, but throw a huge ball of light in highbeam. I have four mounted on my bumper and am very impressed so far.
20035f250 is offline
post #3 of 10 (permalink) Old 11-22-2006, 02:51 PM Thread Starter
I wish, the would be perfect. The problem is that they are getting mounted in the bumper. 8" is a little too big
post #4 of 10 (permalink) Old 11-22-2006, 03:34 PM Thread Starter
Looks like I am going to have to run the 580??
post #5 of 10 (permalink) Old 11-22-2006, 09:29 PM
http://www.piaa.com/Lamps/Lamp-pages/525.html
2004 F-350, 4x4, SC, LB, 6.0PSD, 6spd
Changed a few things. More than some, less than others
Betaracer is offline
post #6 of 10 (permalink) Old 11-23-2006, 12:07 AM Thread Starter
I had to make a choice earlier toay so I went with the 580. My goal was to have all the lights/lenses look same as factory but I am not sure if this is going to work out that way. If the 580 has a whiter light then I will have to find the correct bulbs to make the headligts and stock fog lights the same. I hope I can do that. Most of the pics on the internet show the 580 with a blueish lense. I hope they don't come that way. I want the lense itslf to look clear. Guess I will find out when they get here
post #7 of 10 (permalink) Old 11-23-2006, 01:44 AM
Texas XC Quad Racer
take some after pics with the fog and high beams....
sredish is offline
post #8 of 10 (permalink) Old 11-23-2006, 07:54 AM Thread Starter
10-4:Thumbup: Whats the best way to wire these things you think?? I want then to come on/off with my factory fog lights/dash switch but then highbeam with facory highbeam switch. I know how to wire stuff but if you throw a relay in the mix you lose me
post #9 of 10 (permalink) Old 11-24-2006, 04:56 PM
what does not kill you ..
I have my fog lights wired direct to a switched 12V (key on) This way I can use them with the running lights only. I feel this is the best option for REALLY FOGGY driving. I have my high powered driving lights wired to the Highbeams. This saves oncoming traffic from blindness if I forget to turn them off.
I tied into the Highbeams at the back of the headlight.
WFTREE
1999.5 F450 CC 4x4 315HP/709tq 6 speed with BD short shifter; DP chip: stock, , high idle, 40tow, 80econo, 80 tow, 100, 140,South Bend clutch; ported BB turbo; SPEARCO 6.0 charge air cooler; pop off valve; dieselsite I/C boots; 203 degree thermostat; pillar mounted pyro, boost coolant temp guages; HX hose; shimmed regulator; Tymar intake; zoodad; 4" DP to 4" exhaust to Aeroturbine muffler to 4" chrome stack; Dahl 100 heated fuel filter; in tank/pre pump mod, Hella FF driving & fog lights, Ford of Ocala SUCKS!
WORK TRUCKS '90 F450 7.3 flat bed, '90 Inter 7.3 flatbed, '96 F450 7.3 dump, '96 F800 5.9 Dump, '00 FL60 Cat Lift truck, '02 F150 5.4 pickup, '04 F550 6.0 Dump, '04 f350 6.0 pickup, '07 F550 6.0 Flatbed, '04 f450 dump
wftree is offline
post #10 of 10 (permalink) Old 11-24-2006, 06:03 PM Thread Starter
I was thinking about tapping into the factory harness, but will they draw to much?? I beleiev they come with relay and all thet. On my 04 I can run with just the acc lights on only so it would be a simple wire up if I don't have to worry about too much draw on the factory wires
