afe intake - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by youngPSD, this thread has received 16 replies and been viewed 989 times.
post #1 of 17 (permalink) Old 11-25-2006, 02:21 AM Thread Starter
afe intake
im a young punk and dont have the money for a chip and trans upgrade so i figured for what i do a intake would be good, Should i just get a stage I or stage II if i did any big mods it wont be untill far down the line.
2002 f-250 supercab shortbed on 305/70/16 BFG A/T with 3.73 gear MODS Pyro,Boost,TransTemp Guages 4" MBRP Turbo back exhaust
youngPSD is offline
post #2 of 17 (permalink) Old 11-25-2006, 02:45 AM
if you wanting more power for cheep i would replae your muff/cat with a piece of pipe and install a mild chip
very cheep way to wake it up a lil
if you want a intake i would do a tymar, not quite as fancy, but should make just as much power and prety dang cheep
robert
alldiesels is offline
post #3 of 17 (permalink) Old 11-25-2006, 04:19 PM Thread Starter
i dont want a cheap intake i want to know what would be the best intake for what im going to do and im only buying AFE!
youngPSD is offline
post #4 of 17 (permalink) Old 11-26-2006, 01:49 PM
youngPSD,
The Stage II flows more by a pretty large margin, worth it in the long run. We did a year end discounted buy on them and are passing the savings on and will save you some money!
Mark @ DPPI
Mark_Craig is offline
post #5 of 17 (permalink) Old 11-26-2006, 04:42 PM
CSIPSD's Avatar
So someone gives you a few options and you bite??? You would be money ahead to do the Tymar and a chip, then later on upgrade to a AFE if you really need it... The Tymar type filter filters better, flows just as much and will set you back $50-$80...
But if you want to drop a bunch of cash and get no real increase in HP then the AFE stage 2 is the ****e... But not worth $400-$500...:Thumbup:
CSIPSD is offline
post #6 of 17 (permalink) Old 11-26-2006, 04:48 PM
Destroked
diesel dan's Avatar
Now...you just said you have no money for a chip, you could by a chip and a tymar filter for the price of an AFE intake...:
diesel dan is offline
post #7 of 17 (permalink) Old 11-26-2006, 04:56 PM
moose99psd's Avatar
:iagree :iagree granted the tymar doesnt look so "cool" but its cheap and it works.. being in your position once had i been given these options deffinately would have gone a diffrent route and had a chip much sooner.. and if ur at all mechanically inclined you could build a shroud or something to make it look better.. but if u want to waste close to $500 be our guest.
moose99psd is offline
post #8 of 17 (permalink) Old 11-27-2006, 12:26 AM Thread Starter
Thanks for your input but i dont have money to do a tranny because im paying on my truck and a chip would shorten the life am i right? Which is bad for me and if i lower egt's with an intake thats good. and i didnt mean to bite if you think i did but I never said anything about making more power yet!
youngPSD is offline
post #9 of 17 (permalink) Old 11-27-2006, 02:19 AM
Shorten life? Depends on how you maintain it and DRIVE it. If you hammer it all the time and don't change your oil regularly and fuel filters, then yeah, it'll shorten the life. However, if you keep up on reg maintenance and drive it sensibly, means you can hammer it now and then to show a bit, but not all the time, you'll be fine and happy.
An intake lower EGT's? Don't think so. Besides, the tymar they are talking about will flow as good as if not better than the AFE so if the AFE would do that then so would the Tymar.
6L PWR is offline
post #10 of 17 (permalink) Old 11-27-2006, 12:51 PM
Supporting Vendor
The intake will not make any more power w/out adding fuel. If you want to do an intake and have it be washable and reusable just get a stage 1. If you are wanting to lower EGT's get an exhaust system. MBRP 4" Al for decent money and you will be ready for upgrades down the line. My $.02.
Dave
D2 Hi-Performance
www.d2hiperformance.com
Proud to be a sponser of THE DIESEL GARAGE.COM!
(586) 709-2271
(586) 949-3234
Our rides
Dave P's Truck: 2002 CCSB 6.5" ProComp lift w/ 5100 Bilsteins, Crower Rods, Balanced rotating, coated rod and main bearings, ARP Head and Main studs, Fire Ringed, ported heads, machined and coated Mahle pistons, AFE stg II, Stealth pumps, BD's w/ 0.008 EH tips, D2HP Inconel exhaust valves, D2HP custom pushrods, Custom HX50 bolted to Hmax pedistal, Suncoast Comp trans, Detriot Electrac's front and rear, D2HP transfer case and 1 piece 4" Al driveshaft.
Dave D's Truck: 2002 ECLB Built Ford Tough Package 6" DR lift kit, Bilstein 5100's, 36x15.50R20 MTZ's on 20x10 114 Eagle's, Randy Ellis Bar w/4 8" Stainless ProComp 130W Lights, Custom tunes from DP Tuner, 05 Harley front end, D2HP transfer case and 1 piece Al driveshaft.
Becky P's ride: 2002 Limited Excursion, DVD, heated seats, TS and DP tunes, Edge Juice & Attitude, Dual exhaust, Bilstein stock replacments, AFE.
D2HP is offline
