Posi RearEnd - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by fuzzys69, this thread has received 7 replies and been viewed 720 times.
post #1 of 8 (permalink) Old 12-11-2006, 12:48 AM Thread Starter
fuzzys69's Avatar
Posi RearEnd
In my 97 plow truck, it has one wheel peel. It really suck for plowing and driving in snow. what is a good aftermarket posi rear. i don't think a full locker will be that good for plowing, but im not sure:shrug: . what do you guys think??
i just need to get both tires to spin when i plow or pull.
thanks
Fuzzy
SOLD!!
2003 F-250 SC Shortbox
Singles Club #30
B.O.M.B. Squad #11
Ridin' Dirty Club #14
fuzzys69 is offline
post #2 of 8 (permalink) Old 12-11-2006, 01:07 AM
eaton posi limited slip diff
86 1 tonhauler is offline
post #3 of 8 (permalink) Old 12-11-2006, 01:08 AM
post #4 of 8 (permalink) Old 12-11-2006, 01:09 AM
Texas XC Quad Racer
A TrueTrac is probably your best option.
Call Randys Ring & Pinion at 1-800-298-9541
http://www.ring-pinion.com
You WILL NOT find a better group of people or more experienced with your needs than them.
sredish is offline
post #5 of 8 (permalink) Old 12-11-2006, 01:10 AM Thread Starter
fuzzys69's Avatar
thanks i will check both them out right now
SOLD!!
Singles Club #30
B.O.M.B. Squad #11
fuzzys69 is offline
post #6 of 8 (permalink) Old 12-11-2006, 01:16 AM
i couldnt find randys website i was thinkin them to
post #7 of 8 (permalink) Old 12-11-2006, 01:16 AM
I can't tell from your avatar, but it looks like you have a SRW truck.
Either way you can rebuild the factory LS and restack the clutches/steels and add a spring/spacer for more preload.
Just a cheaper option for ya.
I know the TracLok in the D80 (dually) can be built to twist the axles in two if you want :evil: with just a clutch restack (no parts needed)
I don't think you can get that much bias out of the Sterling unit though.
Sorry, I just read it was your 97...oops
BONE STOCK
444turbodiesel is offline
post #8 of 8 (permalink) Old 12-11-2006, 01:23 AM Thread Starter
fuzzys69's Avatar
its not going in my 03, its going in my plow truck its a 97 f-350 SRW with 4:10
fuzzys69 is offline
