Any Dually's running 22''s or 22.5''s wheels?? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by KoolyDooly, this thread has received 2 replies and been viewed 846 times.
post #1 of 3 (permalink) Old 12-13-2006, 09:08 PM Thread Starter
Im trying to decide between the two, just wondering if anyone knows any info why I should do one over the other. I like the look of both but one guy said with the 22.5's I should get bigger brakes and 4:56 gears. Also wondering if this setup will cause any rubbing or turning issues thanks
KoolyDooly is offline
post #2 of 3 (permalink) Old 12-14-2006, 05:02 AM
laysonw's Avatar
I don't think you would need to go with bigger brakes or 4.56 gears. Only if you lift it and go to a larger size tire. You can actually get a tire that will fit 22's. I have read about guys with 305-40-22 Khumo stx tires. The 305 is actually the same exact height as the factory 16's.... But a 22.5 or 24.5 inch rim might have a lot better selection tires. The big rig tires last like 150,000 miles....
there is alot of information on this site...
http://www.americanforcewheels.com/
Good luck,
Steven
01 12.5" Icon, OUO Traction Blocks, Dynatrac Prosteer Balljoints, SpynTec Conversion, 40" Toyos, GTP38R, Isspro Guages, ORU Diff Covers, Hella 500s, AMP powerstep, Mini Me's, Heat Extractor Hood, custom paint, and BTS tranny!
New Truck Pics
Iraq War Heroes Tribute Page
laysonw is offline
post #3 of 3 (permalink) Old 12-14-2006, 03:24 PM
No need for bigger brakes or gears in my opinion with the 22.5's. My boy turns 22.5s no problem at all on his chevy 3500 LBZ. The overall dimension of his tires measure right at 36". I would opt for the 22.5's as well.
HydrillaHoundawg is offline
