Sliding rear window...... - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by aald4x4, this thread has received 10 replies and been viewed 1909 times.
post #1 of 11 (permalink) Old 12-14-2006, 02:59 PM Thread Starter
My power sliding rear window is ridiculously slow in my 05, I think theres something wrong with it because the power sliding rear window in my 2004 is way faster. Has anyone else had any problems with the window?
I think I saw a kit one time that relocated the power window motor to under the seat, has anyone seen this?
aald4x4 is offline
post #2 of 11 (permalink) Old 12-14-2006, 03:05 PM
is here and there.
Rcannon's Avatar
Images: 11
are they the same motor for both windows? Maybe Ford in their infinite wisdom downsized the motor to save cost.
Rcannon is offline
post #3 of 11 (permalink) Old 12-14-2006, 03:15 PM
Lubricate it and it will speed up to as fast as the o4.
NMU98 is offline
post #4 of 11 (permalink) Old 12-14-2006, 05:11 PM
Do you lube the tracks that the window slides in , or the mechanism that powers it ? and , what lube is recomended ? :thanks:
Doug
fmcdoug is offline
post #5 of 11 (permalink) Old 12-14-2006, 07:33 PM
My power window motors seem extremely slow on my X too. What is up with that? Is it the same thing that aald4X4 has going on?
cdiesel is offline
post #6 of 11 (permalink) Old 12-18-2006, 07:18 PM
mine doesnt have a sliding rear window... how can i add it or where can i get it
imported_powerstrokebronco is offline
post #7 of 11 (permalink) Old 12-18-2006, 10:46 PM
AKA - FFpsd
If you don't lube it and keep using it, it will burn up the motor. Mine got stuck open and I had to have a new one put in. Just lube the bottom track, I used a cable/chain lube seems to work the best.
-Jason
2005 F250 C/C Short Bed
The Diesel Garage
Can You Keep Up???
FireRescuePSD is offline
post #8 of 11 (permalink) Old 12-22-2006, 02:45 AM
Smokin
fordfanatic69's Avatar
Ford replaced mine and it is already slowed way down again. Are you talking about the actual track behind the seat and molding or the track that the windo is sitting in?
09 F250 Crew Cab FX4
5% tint 35% whole windshield w/5% brow
4" lift
35X12.50R20 Toyo
Under cab Lights
Bed Lights
5" Flow Pro No Muffin W/6" tip
Spartan 310
fordfanatic69 is offline
post #9 of 11 (permalink) Old 12-22-2006, 07:44 PM
AKA - FFpsd
The track the window sits in. You can se how the window sits inside a plastic cratle with a cable atached to it...I sprayed the track the cratle slides in and the cable it self. Mine slowed down like you said about 4months after they replaced it now I just keep it lubed and it slides like new.
-Jason
The Diesel Garage
Can You Keep Up???
post #10 of 11 (permalink) Old 12-23-2006, 03:32 AM
Any way to help the windows go down quicker? The drivers window goes down really slow and comes almost to a stop about 3 inches from being completely open...especially bad with the auto function. All the windows are slow to go down and up though. What can I do about this?
cdiesel is offline
