any luck with death wobble?? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by EPDP99, this thread has received 24 replies and been viewed 1277 times.
post #1 of 25 (permalink) Old 12-16-2006, 07:52 PM Thread Starter
I have searched but it appears not solid fixes yet. any updates, my trucks is doing it much more often.... planning on getting the dual setup for this. I checked everything for play and tightness.steering box was rplaced twice. 1st one cases split and replaced. got death wobble after that. replaced box and went away. coming back....steadily getting worse.
EPDP99 is offline
post #2 of 25 (permalink) Old 12-17-2006, 05:34 AM
DSI
Rock Star
Send a message via MSN to DSI Send a message via Yahoo to DSI
i replaced my trac bar with a custom made one. problem solved :evil:
.250 wall DOM tubing QA1 cro-moly heim joint's Grade 8 bolt's... nice and solid
07 Ram 2500 5.9l 48re QC SB Silver
98 BMW 540i 4.4l V8 6speed... 18in Stagered, Chrome Plated ///M5 Par's, Eibach Coils, Bilstein Shocks, 294/324 STOCK!
DSI is offline
post #3 of 25 (permalink) Old 12-17-2006, 10:22 PM
I think I am having a very similar problem. I have a set of dual stabz. on the way, but I would like to know where could I find a trac-bar for mine. Are these expensive?
imported_DieselFord05 is offline
post #4 of 25 (permalink) Old 12-25-2006, 01:10 AM
what is ford doing to fix this??
robert
alldiesels is offline
post #5 of 25 (permalink) Old 12-25-2006, 02:44 AM
Trac bar Smack bar - Dual stab. will help but get a good kit - I suggest SUPERLIFTS with Bilstein shocks and keep tires rotated and balanced.
Its a ***** with a lift and the only kit that seems to not have a problem is Superlifts with all there brackets they give you to keep every thing as close to stock as possible.
Since I have taken out my lift I have logged 18 thousand miles and have not had a wobble since.
snopro99 is offline
post #6 of 25 (permalink) Old 12-25-2006, 03:52 AM
well my 06 will do it bone stock around 65mph (not always) but it only has 200miles on it, what's the deal guys???
i really don't want to bring it in to ford and let them have it for 2weeks
does ford have a fix?
robert
post #7 of 25 (permalink) Old 12-26-2006, 04:02 PM
anything guys?
this is annoying
robert
post #8 of 25 (permalink) Old 12-26-2006, 04:12 PM
put some poly graphite bushings in it
86 1 tonhauler is offline
post #9 of 25 (permalink) Old 12-26-2006, 04:29 PM
BogginF350's Avatar
I was going to do what dsi Did, But it is killing me to drill out my axle taper. I might see if I can have a machine shop make me a taper with stud on the other end to accept the heim.
Josh Davis
6.0L Ford
6.4L Ford
WWW.RIVERCITYDIESEL.COM
(309) 699-2488
BogginF350 is offline
post #10 of 25 (permalink) Old 12-28-2006, 01:11 AM Thread Starter
ford doesnt do anything. there is a tsb to change caster i think raise it but after tire pressure, stabilizer check, balance and roadforce tires. doesnt seem to work and from what i hear there arent doing anything. im gonna go with a dual stabilizer up front and remove stock one. i also heard to try just removing stock stabilezer and that alone has gotten rid of it. maybe sonce it way high on the steering components that it also pushes and pulls up and down making the condition worse than beeing soley used for side to side motions.....worth a try
EPDP99 is offline
