who has the best 33 in tires? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by imported_f250sdford, this thread has received 6 replies and been viewed 798 times.
post #1 of 7 (permalink) Old 12-16-2006, 08:10 PM Thread Starter
Question who has the best 33 in tires?
i'm looking to put on 33 in tires. i was hoping to keep bfgoodrich but all they have is a 285/65/17 which is not that much different from the stock 265/70/17. anyone know a all terrain tire that are 33"?
f250sdford
imported_f250sdford is offline
post #2 of 7 (permalink) Old 12-16-2006, 08:35 PM
coreystroke02
coreystroke02's Avatar
Check out some Nitto Terra Grapplers. I have had a set of 35's which I got 51000 miles out of, and now I have a set of 37's that I'm running. They are great tires and are more quiet than the factory tires. Good Luck!
coreystroke02 is offline
post #3 of 7 (permalink) Old 12-16-2006, 09:53 PM
Squatch's Avatar
BFG also makes a 305-65-17 and a 315-70-17 in the all terrain
http://www.bfgoodrichtires.com/specs...t-a-ko/44.html
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
post #4 of 7 (permalink) Old 12-16-2006, 10:32 PM
In the Toyo Open Country AT, your choices are;
LT285/75R16 - 32.7"
LT295/75R16 - 33.3"
LT305/70R16 - 32.7"
LT285/70R17 - 32.7"
LT275/70R18 - 33.2"
LT325/60R18 - 33.6"
LT305/55R20 - 33.2"
I have this model tire and have been very happy with the ride. I am running a LT325/65R18 = 35" version on 18"x9.5" rims. I found the BFG AT to be a good tire, but didn't have the size I wanted at the time of purchase. These Toyos have a 50,000 mile wear warranty.
2004 F-350, 4x4, SC, LB, 6.0PSD, 6spd
Changed a few things. More than some, less than others
Betaracer is offline
post #5 of 7 (permalink) Old 12-16-2006, 11:43 PM
pro comp
check out the pro comp at's, had a set on my '95 bronco that went for 80k.
mckey73 is offline
post #6 of 7 (permalink) Old 12-17-2006, 10:35 PM
I also have Pro Comp's, but I have the Extreme AT's. They are a great tire. I am not sure if they make 'em in 33's though. You would have to check their website. They are also a very quiet tire for such an aggressive tread design.
2004 F350 Crew Cab 4X4 6.0 PSD
Lariat, Leather, Sunroof
4 1/2 inch Pro Comp lift
35X12.5X18 Pro Comp Extreme All Terrains
1000 Watt Sound System:Thumbup:
MBRP 4-in turbo back w/cat delete
SCT XCal-2 tuned by Innovative Diesel
Intake Elbow
Autometer Z-Series-pyro, tranny, boost on A-pillar
Zoodad
jennamax is offline
post #7 of 7 (permalink) Old 12-18-2006, 07:18 PM
X2 :Thumbup:
2010 F250 6.4 - Stock
SOLD 2001 F250 7.3 Platinum Edition
Garrett Ball-Bearing Turbo/AFE Stage 2/AIH Plug/Sonnax/5" Exhaust/DP-TUNER Chip
R_S_C is offline
