Air System - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by redf2502002, this thread has received 3 replies and been viewed 807 times.
post #1 of 4 (permalink) Old 12-17-2006, 01:04 PM Thread Starter
Air System
Looking for and on board air compressor and tank. Would like to have air horns and beable to have an air supply for tires and what not. Seem to be getting a lot of low or flat tires on trailers lately. Thanks for your help. Red
redf2502002 is offline
post #2 of 4 (permalink) Old 12-17-2006, 09:21 PM
This one is engine driven, but probably pretty pricey. http://www.vmac.ca/index.php?underho...6ab38af7d7e53f
If you are handy at fabricting, you could probably build your own brackets and use a york a/c compressor. They work very well as an air compressor and are cheap at the wrecking yard. Then all you have to do is plumb in a tank and shut off switch.
Here are several 12v options, the Oasis has one of the highest cfm and is a york compressor with an electric motor. If you are not airing up lots of tires the smaller ones will work, but you get what you pay for and you can quickly burn up one with over use. http://offroadrecovery.com/category/aircompressors/
FIREBALL is offline
post #3 of 4 (permalink) Old 12-18-2006, 01:28 AM
TDG MAFIA MEMBER #71
POWER STROKE 99's Avatar
I have a home made rear stainless pipe bumber that was on my truck when I bought it and I took it off, if you want it, you are welcome to it. It was used as a air storage tank. It has an air fitting to fill it built on it. I can take pic if you want it.
POWER STROKE 99 is offline
post #4 of 4 (permalink) Old 12-18-2006, 05:20 PM Thread Starter
THanks, but I think I want something to either mount in my tool box or on the frame of the truck. Plus shipping to Iowa would probably kill me. THanks again. Red
