Lift kit and wheels offset/back spacing ?'s - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cobrat03, this thread has received 8 replies and been viewed 5468 times.
post #1 of 9 (permalink) Old 12-18-2006, 12:20 AM Thread Starter
cobrat03's Avatar
I have an 06' F250 with factory 20" wheels. I want to do a lift kit. I first just wanted a leveling kit but I want to do 20" wheels with 35X12.50 tires and I don't think a leveling kit will do the trick. So I think a 4" lift is in the future. Is the DR 4.5" lift kit $800 better than a Superlift 4" kit. I noticed Superlift offers a Bilstein shock upgrade which I would do, so is the DR really that much better?
Also, what backspacing and offset will work with the tire size 35X12.50 and a 4" lift? I have found some wheels that are 20X9 with a +14 offset and 5 5/8 backspacing. Would that be better that a wheel with 0 or -1 offset and 4 1/2 or 4 5/8 backspacing?
Thanks for your input
Brent
2011 F350 CC SB SRW LARIAT
2 CRAVE OFF ROAD WHEELS 20 X 9
NITTO TRAIL GRAPPLERS 35 X 12.50 X 20
RECON LIGHTS
COLOR COATED GRILL SURROUNDING
H&S BLACK MAXX
4" DPF DELETE EXHAUST
S&B INTAKE
cobrat03 is offline
post #2 of 9 (permalink) Old 12-18-2006, 12:31 AM
MAFIA #8
hhrecovery's Avatar
Images: 1
you can fit 35" tires under your truck w/ just a leveling kit.
2003 F250 "Pulling Truck"
hhrecovery is offline
post #3 of 9 (permalink) Old 12-18-2006, 01:03 AM
Hotsauce2138
Send a message via AIM to HotSauce2138 Send a message via MSN to HotSauce2138
i would suggest a 4.5 DR lift, everyone that i have talked to that has one are really happy with their kit, and their shocks are really good too.
here is a link: http://diabloffroad.com/home.html
the guys name is Dave and he is on France til the 18th but responds to his emails from his site. he is the man to talk to about a lift or anything involving suspensions.
hoep this helps you out.
SAM
Late 99 F-250 CC SWB Lariat 6 sp. 4x4 - the mods= Garrett GTP38R Turbo, DDP Stage 2 Single Shot Injectors. Shimmed Regulator, CCV Reroute and HX Hose from Dfuser, 4" turbo back straight pipe to GR 5" stack kit w/ 7"mitre cut stacks DPPPOWER.COM, AFE Stage 2 Intake w/ PG7, DP Tuner F5 Chip, 18K Mod Dfuser, SouthBend Clutch, Pro Pods quad a-pillar pod, Autometer Ultra-Lite Series Guages ( EGT, Boost 0-35, Trans Temp, Fuel Pressure and Engine oil temp.), Pro tech cab guard, WELD Sidewinders. Road Armor's!!! Custom Pro Tech toolbox/stack cover, , Sirius Sat. Radio, BD Exhaust Brake, 06 Towing Mirrors w/ LED blinkers and heated
:93C_peelo
My Gallery: http://fordtruckworld.tenmagazines.c...y.asp?id=18074
Singles Club Member #52
Can You Keep Up??
Because I'm trying to. lol
HotSauce2138 is offline
post #4 of 9 (permalink) Old 12-18-2006, 01:06 AM
Hotsauce2138
actually just tell Dave what you want your truck to look like and wat tires you want to fit under your truck and he will suggest the best options as far as best look and ride.
b/c he has a 2.5 DR leveling kit or a 4.5 DR lift
just ask him
SAM
:93C_peelo
Can You Keep Up??
post #5 of 9 (permalink) Old 12-18-2006, 01:13 AM Thread Starter
cobrat03's Avatar
Is that using the stock wheels or aftermarket wheels?
RECON LIGHTS
H&S BLACK MAXX
S&B INTAKE
cobrat03 is offline
post #6 of 9 (permalink) Old 12-18-2006, 01:26 AM
MAFIA #8
hhrecovery's Avatar
Images: 1
either one you choose.
post #7 of 9 (permalink) Old 12-19-2006, 12:08 AM
The negative offset will cause you to rub. You need the positive offset or 5 - 5 1/2 inch of bs.
NFA Fun is offline
post #8 of 9 (permalink) Old 12-19-2006, 12:30 AM Thread Starter
cobrat03's Avatar
So if I were to get a +14 offset with a 5 5/8" backspacing and put a 325/60/20 tire on the wheel I should have no issues with clearance?
RECON LIGHTS
H&S BLACK MAXX
S&B INTAKE
cobrat03 is offline
post #9 of 9 (permalink) Old 12-20-2006, 02:16 AM
Squatch's Avatar
I have 18" wheels but dia. should make no differance. With the aftermarket wheels I have and 35x12.5 BFG Mud t/a's there was a little bit of rubbing on the inner fender but I just pulled it back alittle. Wheels are Eagle Alloys 18x9 with 5in backspacing and a +2mm offset and i have a 2.5" leveling kit. With the same tires on my stock wheels there is no rubbing at all since they have a 6in backspacing
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
