traction bars - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by pontiacross, this thread has received 6 replies and been viewed 989 times.
post #1 of 7 (permalink) Old 12-20-2006, 02:42 AM Thread Starter
pontiacross's Avatar
traction bars
Is anyone running a set up like thishttp://www.jcwhitney.com/autoparts/S...searchbtn.y=11
I plan on doing some sled pulling and am getting readey to install a set of stage 2 injectors and a wildman chip, so my suspension is going to need all the help it can get. I thought about makeing my own and beefing them up real good. I like the idea of the bar being above the spring where it is hidden but I guess if I have to go with a lader bar set up thats what I'll do.
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
post #2 of 7 (permalink) Old 12-20-2006, 03:55 AM
Not sure if those will be strong enough. I've seen those break on toyota's rock crawling and sled pulling with a powerstroke would probably push them beyond their limit.
FIREBALL is offline
post #3 of 7 (permalink) Old 12-20-2006, 06:10 AM
I would not trust those with the power you will be putting out. Off Road Unlimited said they would make me a custom set when I go big in my truck. They will cost more than the ones you mentioned, but I wonder how much torque theJC's will really handle???
Forever Stroked is offline
post #4 of 7 (permalink) Old 12-20-2006, 07:02 PM
Supporting Vendor
I am not sure how those would do any good. It would almost give a rotation point for the axle to swing around. If you are going to only locate w/ one bar you want it below the axle to control the wrap and wind up.
Dave
D2 Hi-Performance
www.d2hiperformance.com
Proud to be a sponser of THE DIESEL GARAGE.COM!
(586) 709-2271
(586) 949-3234
Our rides
Dave P's Truck: 2002 CCSB 6.5" ProComp lift w/ 5100 Bilsteins, Crower Rods, Balanced rotating, coated rod and main bearings, ARP Head and Main studs, Fire Ringed, ported heads, machined and coated Mahle pistons, AFE stg II, Stealth pumps, BD's w/ 0.008 EH tips, D2HP Inconel exhaust valves, D2HP custom pushrods, Custom HX50 bolted to Hmax pedistal, Suncoast Comp trans, Detriot Electrac's front and rear, D2HP transfer case and 1 piece 4" Al driveshaft.
Dave D's Truck: 2002 ECLB Built Ford Tough Package 6" DR lift kit, Bilstein 5100's, 36x15.50R20 MTZ's on 20x10 114 Eagle's, Randy Ellis Bar w/4 8" Stainless ProComp 130W Lights, Custom tunes from DP Tuner, 05 Harley front end, D2HP transfer case and 1 piece Al driveshaft.
Becky P's ride: 2002 Limited Excursion, DVD, heated seats, TS and DP tunes, Edge Juice & Attitude, Dual exhaust, Bilstein stock replacments, AFE.
D2HP is offline
post #5 of 7 (permalink) Old 12-21-2006, 12:15 AM
It doesn't matter if the bar is above or below the axle as long as it triangulates from the front bushing to the bottom of the leaf spring where the axle attaches and some other point. In this case a point above the axle. They do work but I wouldn't use them for this application. I had them on my '83 and my '94 Rangers. On the '83 if I side stepped the clutch with my foot to the floor it would warp so bad that it would bind the U joint and I actually bent a drive line from doing it. It fixed that problem. Didn't really notice a difference in every day driving though. When I got my '94 I put them on it and with the greater power of the 4.0L V6 vs the 2.8L V6 in the '83 I noticed a big difference in take off. Felt like when I let the clutch out it just went where before it felt like it loaded the suspension then took off. Didn't really notice it until I put them on and then you could tell a big difference. But that was on a 160 hp small truck that made about 225 ft/lbs of torque not on a big heavy truck that you're putting a big load on. For what you want IMHO the only way to go is with a ladder bar with two mounting points on the rear axle and a shackle on the front end of the bar where it attaches to the frame. That wont allow for any axle wrap at all what so ever!
466 on #2 only
739 with NČO
13.544 in 1/4 mi!
Yeah I can keep up!:Thumbup:
gtspowerstroke is offline
post #6 of 7 (permalink) Old 12-21-2006, 01:18 AM Thread Starter
Thanks for the input I was mainly interested in them because of the fact That they would be hidden and I trying to keep my pickup looking stock. Maybe I try and make a set of ladder bars that can come on and off easily so I can bolt them on when I'm pulling and take them off when I'm on the street.
Ross
Tow Rig
post #7 of 7 (permalink) Old 12-21-2006, 04:46 AM
The concept of those bars isn't bad, it's just that they are nowhere near beefy enough for the kind of torque these trucks are putting out. You may be able to fab something similar, or fab a ladder bar that is tucked up rather than hanging down. I think part of the reason you see those ladder bars hanging down is because it makes sells to the guys that want the bling as well as the guys that actually use them.
FIREBALL is offline
